Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Instructional program for Magnavox won't turn off, and can't use the remote
Hi I obtained a 1994 Magnavox t.v. from my brother. I was using a universal RCA remote for which my boyfriend put in the code and that worked fine. Then I apparently pressed buttons I shouldn't have because now an instructional program for Magnavox keeps running automatically and I can't get it to turn off. The t.v. no longer responds to the remote. I also can't use the buttons on the t.v. The only way I can turn it off is to unplug it!
How do I "reset" it and get this program to stop running?
Thank you,
Valerie
  • 1 more comment
  • vamurphy Jul 10, 2008
    I forgot to tell you the model number. It's 25B501-00AA. At this point I think the only solution might be to have a t.v. repair person look at it. But I don't know if it's worth spending that kind of money on it.
    Thanks,
    Valerie
  • vamurphy Jul 13, 2008
    Hi m_maricruz:
    Thank you so much for your solution. As it turns out my boyfriend had suggested pressing all the buttons at once a couple days ago and it worked! But if he hadn't suggested it I would have learned about it from you. It's so great to have my t.v. back. Thanks again for your help!
    Valerie
  • Anonymous Oct 16, 2008
    words on screen
I just did a search today because my kids have the same tv. I found out if you push the volume + and channel + at the same time for about 5 seconds, the tv shuts off and resets. It is in factory mode. Give it a try, if that doesn't work try volume - and channel - at the same time.
Posted on Jul 12, 2008
Have a Philips/Magnavox remote that's already programed to the television, how do I hook my Philips remote to magnavox converter box and know codes/instructions to turn box on
If your Philips/Magnavox remote is pre-programmed, try pressing a device button other than TV and see what happens. If your remote is universal, you can use code search to find something that will work.
Jul 15, 2016 | Philips Televison & Video
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Magnavox code
Magnavox digital converter codes are unique. It has beeen my experience that only the Magnavox remote works. No other universal remotes will do
Sep 29, 2013 | RCA RCRN04GR Remote Control
Have RCA remote need code or no how to program it to my magnavox dvd player
Hello
Setup codes for Magnavox DVD with RCA RCU-404 universal remote control are:
057, 060, 074
OK.
Jul 19, 2011 | RCA RCU404 Remote Control
Magnavox blue ray dvd. model nbmgf c need remote code for dish network
Hi there! In order to be able to provide the definite codes that will allow you to program your remote to your Magnavox Blue Ray DVD player, I would need the type of remote that you have- this can be found on the back of your remote, it would be displayed as something along the lines of 3.0, 4.0, 5.0, etc. To obtain a few codes that will likely allow you to successfully program the remote I used 5.0 because it is a common remote that is used with quite a few of our DISH Network receivers. The codes you can try for your DVD player would be, 829 (most successful) if not then please try the following, 685, 533, 554, or 556. After trying those codes if your attempts are still unsuccessful you can also check the manual that came with the DVD player from the manufacturer or just contact us here at DISH Network - although I do know sometimes the remote codes can be located in the manual. Hope the codes help & work for you!
-Kirstie DISH Network
Oct 05, 2010 | DISH Network IR Remote Control
Need a tv code for Magnavox. Using
Code for Magnavox TV are
0054, 0030, 0179, 1254
Thanx
Aug 01, 2010 | One For All URC-3300 Remote Control
I have a universal remote and need the code for a magnavox dvd player to program the dvd player thank you
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed (VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 28, 2010 | RCA RCU404 Remote Control
I need the codes for my remote control
There are numerous codes listed for a magnavox dvd player (URC4220 user manual page 36) as the manual doesn't give definative code as there are quite a few different magnavox dvd players, you will need to try each of these codes in turn and one should work:
0503, 0539, 0646, 0675, 0821, 1268
If you need the manual for this particular remote then you can use the link below to take you to the one for all remote control support site where you can enter your remote control model number and view or download the manual this may also help you to program your remote.
http://www.oneforall.com/support/manual
Hope this helps
James
Apr 26, 2010 | One For All URC4220 Remote Control
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
149 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
