Question about Whirlpool LER4634J Electric Dryer
I have a whirlpool dryer model LER 7646EQ1 that will not heat. I have looked at the heating element seems to be ok not broken. How do I check the thermostat and fuse to see if they are good.
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Jan 01, 2011
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
DRYER WHIRLPOOL LER 6646 SERNO. MS23065579 IT RUNS BUT NO HEAT OUTPUT TO DRY CLOTHES
I would suggest replacing the heating element these are usually always the culprit and pretty much anybody can replace them.
Check here for parts for you model number, they also have good diagrams.
Hope this helps, thanks.
May 12, 2011 | Dryers
Whirlpool dryer ler 7620 kq8 Dryer not heating I replaced the heating element and it is still not heating. what do you think it is?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Whirlpool LER7646E Dryer
My LER 7648PQ0 whirlpool dryer doesn't heat but motor runs and programmer seems to run right. What is the problem ? I use an 220 V => 110 v transformer. How can I connect electrical wires at the back...
is your dryer 110v or 220v? If everything works except the heating element the element is bad or the one time fuse has popped it has two wires on it and one runs to the heating element or the hi temp switch on the heating element the fuse will be a small disc type when removed do not mistake the hi temp switch it is located on the element housing the one time fuse is ususally located on the dryer its self all of this is accessed on the back of the dryer under the back panel. good luck. (ground and common are the same in homes in mobile homes they are seperate and the dryers are 4 wire plugs L1 ,L2,neutral and ground).
Aug 08, 2010 | Dryers
I don't know anything about dryers so please bear with me. My dryer drum turns, fan blows, but wont heat. replaced heating element. Still no heat. Has 124 volts on both prongs of element. What should i do?...
Have you tried flipping the breakers @ your electrical box? Mine will do that at time when one breaker has tripped. It will have enough juice to run it but not heat it. IF that doesn't work there may be a broken wire to the heating element or possibly even a faulty heating element. I'd try the breakers first though.(Im not a professional I've just been a single mom for 18 years and have found myself working on all sorts of things and gaining knowledge from hands on experience) Hope it helps & works.
Aug 03, 2010 | Whirlpool Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryer will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Sep 24, 2009 | Whirlpool LER4600 Electric Dryer
Electric dryer has not heat model # ler 4600
Normally caused by bad thermostats and or heating element
Sep 24, 2009 | Whirlpool Dryers
Whirlpool LER4634J Electric Dryer Logo
278 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
