Question about RCA Universal Remote Control
Remote control Does the power have to be on before you can program a universal remote? My tv power on button doesn't work Mark
  • Anonymous Mar 19, 2014
    tv no power button and no remote
  • 100 Answers
Greetings mftillman,
As long as your television is plugged in that should be fine. Normally with most universal remotes it tests that the correct code is entered by pressing the power key and turning on your television.
Happy Channel Surfing,
Go Ahead. Use Us.
Posted on Jul 08, 2008
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
The remote doesn't work for any of the DVD functions.
1 replace the old batteries use new ones alkalines with the same mark and polarities.
2) clean the contacts batteries with c. cleaner.
3) open the remote control, and clean the keypads from dirty, oxide, corrosion, with c. cleaner.
4 Proceed again, if the problem persist, you must go to the repair shop TV or replace by new ones.
God bless you
Nov 11, 2012 | Televison & Video
I have a ge universal remote and a panasonic tv but i dont have the directions on how to program it or what the codes are to set it up. i need step by step instructions.please help
There are two types of GE universal remotes. Does your remote use the 4-digit code or the 3-digit code?
These codes listed below are not for combination TVs (TV/VCR, or TV/DVD). If you have a combination tv, see the appropriate code list here: .
The 3 digit codes for Panasonic TVs are 003, 054, 055, 062, 070, 148, 149, 170, 171, 374, 381, 437 . If you have an LCD or Plasma Panasonic only try 170.
The 4 digit codes to try for Panasonic TVs are 1182, 0171, 0148, 0054, 0170, 0062, 0374, 0381, 0437, 0950, 0003, 0070 .
Next to program the remote: Turn on the TV manually. Press and hold the Code Search or Setup button (depending on your remote). Hold the button until the indicator light comes on and then release it. Then press and release the TV button. Type in the first code for your remote and TV combination. The indicator light should go off. Then point the remote at the TV and see if the TV turns off. If it doesn't, repeat the above steps. Once you have a code that seems to work, check if the remote controls all of the functions that you need (based on the available buttons on the remote). If you have a code that turns off the TV but doesn't control other functions, continue trying other codes.
There is an option to search through all of the codes of the remote to program the remote. Press and hold the Code Search or Setup button. Release the button when the indicator light comes on. Then press and release the TV button. Now press and release the Power button on the remote repeatedly and wait until the TV turns off. Do this slowly (pressing the Power button every 2 seconds). When the TV turns off, press Enter on the remote to save the code. Then test the remote. If the remote doesn't control all the functions of the TV that you want it to, then repeat the search.
Please note that the codes in most universal remotes are limited to those for devices released 6 months or more before the remote was programmed. If your remote is older than your TV, then you may need a new remote.
I hope this helps.
Aug 06, 2011 | GE JASRM24912 Remote Control
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: . You can also scan all of the codes to find the correct one: see . Additional remote/receiver manuals are here: .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Jul 09, 2011 | DISH Network IR Remote Control
I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
The manuals and code lists for GE remotes are here: .
Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
.............0105 0049 0095 0170 0260 0358
.............0394 0924 0012 0095 0117 0141
The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
I hope this helps.
Jul 06, 2011 | RCA Televison & Video
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Find codes and methods here.
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
Im having problems programing my sansui flat screen tv when i program my rcr311b universal remote it works up untill the point when the tv turns off after pressing the play button and releasing the reverse...
first wat are u trying to do,,,,,,in mind....wat way,,,,,to do wat....try going to get thing that can remote w/remote to do......reverse the plan of mind,,,,
Aug 27, 2010 | RCA RCR311B Remote Control
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Dec 27, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
