Question about Onkyo TX-SV525 Receiver
Receiver goes into protect mode after fifteen seconds of pushing power button. I think a pair of speaker wires crossed.
    Brigadier General:
  • 8,546 Answers
The manual is here:
http://www.retrevo.com/s/Onkyo-TX-SV525-Receivers-review-manual/id/365bh226/t/1-2/
Power it OFF before handling any wiring.
You could verify if any speaker wires being shorted is the problem by just disconnecting all of them and trying to power it up. If it fails to power up, it's sick and needs a hands-on tech to look at it.
If you don't actually SEE the problem while disconnecting the speakers, but the receiver DOES come on, try reattaching one at a time until you either have found the offending speaker/wire combination or you have success in turning it on and using it.
Speakers can be shorted, too. So if you locate a channel giving you trouble, say, front right, you could swap a different speaker or wire set into its place to prove if it's external or internal to the receiver.
Going forward, make sure you don't run the unit too loudly and give it plenty of room for cooling ventilation.
Posted on Jan 01, 2011
To fix cpu on protection mode
I am highly skeptical that the CPU is the problem; protection mode is designed for protection of the amplifiers.
Use an artists brush to remove any dust and grime off the voltage rails and heat sinks. Reinstall the CPU and the chassis cover. Turn your attention to the rear connector panel; check for any broken or loose speaker terminals. If your speaker wires are still connected look for any stray wire strands and pull them off or bend them away from the connector panel. Check the connection for tightness, or simply disconnect any corroded wiring that you may not be using a banana or spade connector with and clip and redress it. Perform the same inspecting and maintaining procedures on all of your speaker channels.
When placing the receiver it must also have adequate air flow around it. Anything you can imagine that would allow the unit to retain heat increases the chance of it getting it into protect mode for thermal protection. Out in open air is best.
When the receiver is properly positioned and all connections are secure, power it up; it will likely still be in protect mode. If so, press and hold the power button down until the unit "clicks" inside the chassis; this takes approximately 15 seconds. Protection circuit is reset and you can now operate the receiver.
Feb 21, 2012 | Sony STR-DE597 Receiver
I touched speaker wire from the receiver to hot wires on my subwoofer and everything shut down, now the receiver will not power on. When I push the on button I get a click noise, but if I keep trying to...
When the speaker wires were shorted it would have damaged the output and so there is a short in the output circuit thereby the amplifier goes into the protect mode. So remove the power and the speakers, reset and test again without the speakers. If the amp goes to the protect mode then you need to have assistance to check the boards within for a short. sometimes it is difficult to probe for a voltage check and so will need jigs to test.
Check the output drivers for short using a multimter, check for the rail voltage to the outputs or there can be a power issue.
Oct 07, 2011 | Yamaha RX-V550 Receiver
Hi, after i turn the power on and then press the stand-by button, it clicks off to stand-by mode instantly. This is an Onkyo TX-SR500
This indicates that the system is going into protect mode. First disconnect all speaker wires (with the power cable disconnected). Then turn the unit on and see if it sill shuts aff ofter a few seconds. If it does not, then you have a problem with the speakers or speaker wires. inspect the wires at both ends for frayed strands that may touch. If that all lookd good, plu the speakers in, one at a time, until the problem reappears. Be sure to turn the sytem off before plugging in any speaker just to prevent any accidental short which could be catastrophic. If the system goes into protect mode with all speakers disconnected, you probably have a shorted output transistor.
Apr 05, 2010 | Onkyo TX-SR500 Receiver
When i switch on my samsung HT-Z110 the word hello appears then protect thenit turned off!
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Nov 29, 2009 | Samsung HT-DB600 System
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
Amp comes on and goes right into protection mode saw the decibel display briefly, received the "Protect" message on the display. can you pliz help me on how i can deactivate the protection....
Protection is usually a sign of overheating or something is wrong at the power amplifier's output.
Theory: Protection is a delay and sometimes an internal test to allow the electronics to stabilize during power up before they are allowed to interact with the speakers. The most common cause of it remaining ON is that a speaker cable pair is shorted. Some isolation is required...
1. Turn the Power OFF.
2. Disconnect each set of the speaker wires that are directly attached to the receiver. Mark them so you remember where each one went. pay special attention to which conductor is on "+" or "POS" and which is on "-", "COM" or "Ground". You may elect to disconnect them one pair at a time if your sytem is complex and you don't want to lose track of where things were.
Turn the Power ON. Is the "Protect" indication gone from the display?
If YES, you have a shorted speaker wire or speaker. To isolate the specific cause:
2. Attach ONE speaker wire pair at a time and test it by turning the Receiver ON. When the "Protect" light returns you have isolated at least one of the cause(s). Disconnect the defective speaker cable and continue isolation of all speaker cables. Visually examine the cable at both ends for frayed wires that could touch each other or contact metal on the receiver or other objects.
To isolate further within the cable/speaker pair - disconnect the speaker end of the cable on the failing path. Try another cable that you know works, or at least one that doesn't cause Protection to stay on.
If you're electrically savvy and have a Digital Volt/Ohm Meter you can troubleshoot the short(s) with it.
If NO, there is probably an internal problem.
Is it solid or does it come on after the Receiver has been ON awhile.
It could be overheating.
Is the unit hot to the touch?
Is there a cooling device (fan)?
Is it stopped or clogged with dust?
Is there adequate ventilation around the unit for air to flow?
Clean any ventilation slots on the top and bottom of the unit.
Avoid stacking components that produce heat under an amplifier or receiver. Their heat rises. Also keep them away from other heat sources like like home heating vents and radiators.
Problem solid and NOT related to the speakers or heat: internal malfunction.
Let me know.
Apr 06, 2009 | Onkyo TX-DS787 Receiver
The dvr99 3 dvd home theater receiver will not stay on
Protect kicks on commonly when it over heats or when the speaker wires are crossed and it detects a short on the output. Your symptom sounds as though it may be a speaker wire because it happens right after the power is turned on. Check the speaker wire carefully, it has a habit of breaking inside the connectors of both the receiver and the speakers, especially after 5 years of service.
Feb 27, 2009 | Audio Players & Recorders
When turned on it say's protect
take out all of your speaker wires on amplifier and on speakers and rewire them all. it is a crossed wire. a stray wire from the negative side is contacting the positive terminal either on the amplifier side or speaker side so just make sure to redo them all and make nice good tight twists when connecting.
Feb 23, 2009 | Teac AG-D8900 Receiver
I have a technics and everytime i plug in it keeps clicking but nothing else the power button lights up
I dont know what kind of clicking is being heard. It might sound like a dead power transformer not clicking over. Or it might be you have some crossed speaker wires. If you did any kind of rewiring recently remove and cut off 1 inch on all ends of speaker wire at receiver end as well as speaker side and twist nice and tightly to not allow any stray wires from crossing over to the other terminals. Sometimes speakers have a protect mode when it sees a crossed cable. I am not quite sure but it is a good place to start looking. Good luck.
Feb 19, 2009 | Technics Audio Players & Recorders
Turns it self off with a sparking noise in the speakers
The unit has a built in protection mode if a fault occurs in the speaker wiring. If its in protection mode the power button light will flash and display goes blank. Try disconnecting all speakers and see if it stays on, if so it could be a shorted speaker wire or bad speaker.
Dec 23, 2007 | Denon AVR-3805 Receiver
131 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
