Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
The motor turns but does not push water - Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
    Problem Solver:
  • 9 Answers
Did you forget to open the valves on either side of the pump after draining and filling perhaps ?
Posted on Jan 27, 2011
My passenger window is stuck and won't close what do I do?
Stuck windows can be caused by:
1.Window rubber channels dirty or broken. Try pushing the window down or up while pushing the window riser switch. If it moves with the push, the window channels are dirty. Cleang up the window rubber channels first with water and soap, then push the window glass up and down while pushing the window riser on. If windows do not move, it could be caused by no power supply to motor (#2 or # 3) or broken riser gears
2. No power to your window riser motor. check your fuses. 3 Burn out window riser motor. - Replace motor.
4.If motor turns, but windows does not move, it could be caused by broken window riser gears, and need to be replaced.
Do all of these by removing the door side panels first and inspect the rubber channels, motor connections.
Oct 12, 2014 | Kia Optima Cars & Trucks
In the first cycle just before the water gets pumped out it stops and doesn't continue.So I found out as I pushed on the lid switch a few times that the machines cycle dial would start and would finish all...
My next step would be to open the unit up and be able to observe (safely) the timer/switch. There is a motor turning a cog wheel, that pushes and releases the electrical switches.
You want to witness the turn rate of this drum, or be able to see the motor output gears......then run the machine to the problem position and observe....
If the motor is NOT runing and the cog wheel is NOT turning, something is interrupting, perhaps a safety switch like the lid switch....
If the motor is running and the cog wheel is turning, you need more patience... Some designs reverse the motor and there is quite a number of degrees of that cog wheel that in needs to trun through, or they run the risk of damaging the motor, so a pause cycle...
Be sure that BOTH hot and cold water hoses are hooked up, on and flowing. Some machines stop waiting for cold water.
(This happens when hoses are reversed going into the machine, Dad gets large hot water bill, has fit, goes and turns off the hot water (which was hooked up to the cold water tap...) and a machine will need filling and wait forever with no water flowing into machine. Often you get a buzz of the water valve, while the machine waits.)
Dec 24, 2010 | Westinghouse WWS833ES Super Capacity Top...
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My electric pressure washer's motor will not start. the 110 plug has a test/reset fuse on it. when i plug it in the light comes on. i push test- it turns off but motor does not run. i push reset and...
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up.
Apr 15, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Water won't drain
Water is pumped out via the outlet motor pump. This motor is in line with the outlet pipe and should spin when the outpump mode. You can check that the motor is spinning in the outpump mode. AC voltage must bo on the 2 push on electrical connections in outpump mode. If voltage is present but motor does not turn, the motor is open circuit and needs replacing. Check that the pipe is not blocked and check that the impeler in the motor turn freely.
Jan 23, 2010 | Dishwashers
Would improperly loading a dishwasher cause the motor to burn out?
No, it wouldn't clean as well, but it will not make the motor go out. The motor just pushes out the water. the water turns the water wheels.
Oct 23, 2009 | Dishwashers
My ice maker makes plenty of ice, no problem with the water either. My problem is that the auger will not turn to dispense the ice out of the bin. The motor kicks on when you push in the buttom, however it...
Pull the ice bucket out, then hold in on the door light switches and while you push a glass into the button for ice (may require two people). Ice dispenser and auger will only work, when you push for ice, when the freezer door is closed, so by holding the light switch(s) in the off position with door open you can simulate door being closed. If you can push the button and see the auger drive turn (with ice bucket out) then check to see if you have some ice stuck between the blades on the bucket, if the auger motor doesn't turn, it may be "ice frozen". Common problem. Remove motor, let sit on counter for about three hours and then reinstall, if it then works then check for water dripping from the fill tube, where the water comes into freezer for the ice maker, and see if it is dripping onto auger motor.
If you put auger motor back in and it still won't turn then more and likely you need an auger motor.
Let me know.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
My outside air conditioner fan is not turning, but when I push the reset button it runs for a while and begins cooling? Then it stops turning and gets hot inside again? What could be the deal?? It was 112...
if the button your pushing is in the unit outside it is a manual reset for high head pressure this cuts off the unit to protect the compressor,you need to clean the coil .turn the unit off and gently push water through the coil in an up and down motion till water comes out clean see if that helps
Jun 26, 2009 | Ruud Central System Air Conditioner
GE side by side not dispensing ice out front
could be frozen auger motor, try turning motor by hand.
May 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
66 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
