FixYa.com
Tags:
Dryers
Generic problem for all Dryers
Dryer starts and the
posted by wlaughlin on Jul 08, 2008
dryer starts and the gas poilt light and the gas value opens and stays open for 15 seconds then shuts off.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 08, 2008
Not Rated (0)
Illeagle
Rank:Guru Guru
Rating: 85%, 184 votes
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Restricted venting Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Restricted venting
Inspect your venting, if it is plugged it will cause the hi-limit safety switch to cycle off to prevent a fire.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE DSXH47EGWW Electric Dryer GE DSXH43EF Electric Dryer GE DHDVH52GFWW Gas Dryer GE DLSR483EE Electric Dryer GE DPXB515EBWW / DPXB515EBCC Electric Dryer GE DSKP233EWWH Spacemaker Electric Portable Dryer GE DPGT750GC Gas Dryer
Can you Help with these Dryers problems?
Dryers
dryer model drcs68w start light
dryer model drcs68w start light... Answer This...
Dryers
I have a kenmore 80's
I have a kenmore 80's series... Answer This...
Asko T700 Electric Commercial Dryer
Asko dryer now makes alot of...
I have had my Asko for about 1... Answer This...
Frigidaire GLER341A Electric Dryer
wiring diagram
replaced heating element,and... Answer This...
Dryers
hotpoint aquarius ctd00 blows...
every time i plug it in it... Answer This...
Repair Service
Find Dryer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
