Question about Whirlpool LER5636P Electric Dryer
MAYTAG ADMIRAL DRYER MODEL LNC7764A71 STOPPED RUNNING ABRUPTLY DURING A CYCLE AND WILL NOT START IT HAS POWER AND THE THERMAL FUSE HAS BEEN REPLACED STILL NOTHING
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Admiral Dryer Model LNC7764A71 - Loud Vibration, everything else is fine
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 08, 2010 | Maytag Dryers
Admiral dryer LNC7764A71 stopped running tryin to figure out how to take it apart to see if its the belt or motor. We are beginners at trying to fix things. I thought I had left the oven on when I noticed...
The front comes off. There are clips on the bottom and flat pegs on the top of the panel. Take a putty knife and slide it between the top and front. Pry down and the top of the panel will pull out. Make sure you don't pull wires loose from door switch when you get it un-clipped. Once you are into the unit, you will most likely find that the thermal fuse is blown. If so you will also need to replace the cycling thermostat. When it goes bad, it puts the thermal fuse out. What you smelt was the dryer getting to hot because the thermostat went bad so it by passed the thermostat and got so hot that the thermal fuse was blown. This is the way the unit is designed to work when the thermostat goes bad. The thermal fuse is a safety.
Oct 16, 2009 | Whirlpool LER5636P Electric Dryer
The Dryer stopped and will not start again
Just had a similar problem with our Maytag Electric Dryer. The dryer shut off mid-cycle and wouldn't start again, but the timer kept running. We purchased a "Thermal fuse replacement kit" at a local appliance parts store for $38 and replaced the fuse ourselves. The dryer is running great! Here's a couple of website links that were helpful in figuring out out how to replace the fuse: http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Hope this helps!
Jul 09, 2009 | Maytag PYE2300AY Electric Dryer
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Dryer won't start
Thermal fuse is your most likely suspect LA 1053
Dec 10, 2008 | Dryers
My Maytag dryer won't start when I hit the start button
My dryer light comes on for my Maytag SDE4606AYW dryer when you open the door and I can hear the timer clicking but when I hit start the motor doesn't even attempt to start but there is obviously power. My dad just installed a new power cord to the dryer but this is a seperate issue as we were obviously unable to check the motor before we got a cord for it. He has years of electrical experience so I'm assuming he connected the new cord right. Any ideas on fuses in the dryer or why it may not be getting power?
Jan 15, 2008 | Maytag PYE2300AY Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
600 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
