Question about Gateway GM5664 Desktop PC
Gateway GM5664 AMD Phenom 9600 (64 quad) wont install windows 7 goes slow as in hours, and hangs in last section for hours. has 3gb memory. working fine until main C HD had corrupt index file that it could not recover from. was running Vista 32bit. was fine until a corrupted download from interweave with faulty adobe AIR. HD crashed after trying to install the interweave application (538mb download) Had 2-500GB western Digital Caviar HD. tried to replace both with Western Digital 1.5TB Green Caviar. Win7 install same speed. MS Tech had me swap out to old D drive of 500GB but still wont install Win7 I wanted to try Ubunto on flash drive to do system diagnostics on motherboard / drives / memory. but no one i now has ability to write CD or Usb flash drive.
Geekman
  • 32281 Answers
SOURCE: Gateway mx7118 says drive has corrupt files cant repair using win
You don't need to change or buy another hard drive, unless you want to install a larger size hard drive.
Boot up with the Windows CD and reinstall Windows.
Posted on Jan 07, 2009
  • 148 Answers
SOURCE: At about 3:00 am on thursdays, Windows XP closes
Sounds like the computer is coming from sleep, standby or hibernation mode. Go to the power settings in the control panel, and disable all of these options. Disable your screen saver as well. Leave the machine on for a day and see if it happens again after this. Post your findings, please...
Posted on Mar 22, 2009
  • 13433 Answers
SOURCE: Error 39, corrupt DVD/CD-Rom Drive
Heres the solution to that problem.
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Posted on May 03, 2009
joecomputer
  • 92 Answers
SOURCE: Gateway T-1625 - System only recognizes parts of the Memory
I bet that the video card on the motherboard is using some of your main memory. As for the cpu driver I would go to the device manager and revert back to last driver or use a utillity like Uniblue's DriverScaner.
Posted on Jun 06, 2009
  • 71 Answers
SOURCE: how to reinstall windows xp if files are missing??
CLEAN INSTALLATION
NOTE: Before proceeding, make sure all necessary backups are completed.
* Insert the Windows XP Reinstallation CD into the top CD drive
* Remove any external devices from the computer: (except the mouse & keyboard) printer, scanner, camera, joystick
* Configure your computer to boot to the top CD\DVD\CD-R -RW\DVD+R +RW drive
- Restart the system
- When the logo screen appears, press the [F2] key to enter the System Setup program
- Press the [Down Arrow] key on your keyboard to highlight Boot Sequence
- [press Enter] to display the available boot devices
- Press the [Up Arrow] key or the [Down Arrow] key to highlight IDE CD-ROM Device
- Press the [plus +] key or the [minus -] key on the keyboard to move IDE CD-ROM Device to the TOP of the list
- Press the [ESC] key
- Press the [ESC] key to Save Changes and Exit
- When you are prompted to Save changes and exit now, [press Enter]
* Your system will now boot to the Windows XP CD that you had inserted into the CD drive
* The following message appears: Press any key to boot from the CD
* Press the [Spacebar] to boot to the Windows XP CD. The Windows XP Setup screen appears
* [press Enter]to setup Windows. The Windows XP Licensing Agreement screen appears
* Press the [F8] key to accept the license agreement. The partitioning screen appears
* If the hard drive is already partitioned (this is most common), [press Enter]to continue.
* If the hard drive partitions are not listed or detected, you will need to create a partition on the hard drive. Press the [C] key and then follow the on-screen prompts to create a partition. If you are unsure which settings to select, you may want to use the default selections that are displayed
* If your hard drive already contains a copy of a Windows operating system, a Caution screen appears. Press the [C] key to continue. The format options screen appears:
- Format the partition using the NTFS file system (Quick)
- Format the partition using the FAT file system (Quick)
- Leave the current file system in place (no changes)
* Dell recommends that you select the first option since that is how we shipped it from the factory
* Choose "Format the partition using the NTFS file system (Quick)", then [press Enter]. The Caution screen appears if you select to format the hard drive
* Press the [F] key to format the hard drive. The setup program will now copy files to your system. This will take several minutes, please wait. After the files have been copied, a message appears and notifies you that the computer will be restarted
* Press the [Enter] key to restart the computer or a timer will count down and restart the computer automatically
* When the computer restarts, the following message appears: Press any key to boot from the CD. Do NOT press any keys!!!
* The Windows XP Setup window appears. Many devices will be detected during this process. This will take several minutes, please wait
* Once this process is completed, the Regional and Language Options window appears
* Click Next
* The Personalize Your Software window appears.
* In the Name: field, type your name. Optionally, you may type your organization's name into the Organization: field
* Click Next
* If you are installing Windows XP Home Edition, the "What's your computer's name" window appears
* Click Next to accept the default selections
* If you are installing Windows XP Professional: The Computer Name and Administrator Password window appears
* Type a name for this computer in the Computer Name: field (or you may accept the default). Type a password in the Administrator Password: field and then type the same password in the Confirm Password: field. Click Next to continue.
NOTE: If you have a modem installed in your computer, you may be prompted to type the area code for your location.
* The Date and Time Settings window appears. Click to select the appropriate time zone for your location from the Time Zone field
* Click Next
* Depending upon your network configuration, you may be prompted for additional information regarding your network card (such as the domain name and workgroup name). If you are unsure of these settings, contact your Network Administrator or accept the default selections. After all hardware has been detected and the files have been copied to the hard drive, the system will restart. When the computer restarts, the following message appears: Press any key to boot from the CD. Do NOT press any keys!!!
* Once the Desktop appears, eject/remove the black Operating System Reinstallation CD from the top CD\DVD\CD-R -RW\DVD+R +RW drive
* You may be prompted for user information. Type the name of any additional users that will be using the computer
* Click Next to continue
After installing the operating system, you need to install the drivers and software for the system.
Posted on Jun 18, 2009
Adding 2 gb memory in a m5100
You can as long s you have room on the motherboard, its the correct type. Memory can be tricky to get it to be recognized and have the system ecognize it. Most issues are with the OS, especially any Windows based system, thanks to Microsoft's usual nonsense.
Mar 01, 2012 | Acer Aspire M5100 AM5100-U5313A AMD...
My acer laptop wont start up a disk read error status:oxcoooooe9
Sorry to be the bearer of bad news, but you have a system registry corruption. If you can boot into safe mode, by presssing F8(though on some computers it is F10 or F12), then perform a system restore to the last known good configuration.
If that does not work, boot your laptop to your OS disk, choosing to repair the installation.
Finally if that does not work, you will have to format your hard drive and reinstall your OS.
Jun 22, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
My Acer Aspire M5100 turns on, but it doesnt work. the USBs wont work either
its time to start shoping for a new computer that model is known to stop working after 2-4 month due to a flaw in design it may have overheated
Apr 02, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
MY AMD PHENOM QUAD CORE HEAT SINK FAN IS NOT
First, check for dust. Compressed air works to clean it out.
Second, if the fan is not spinning at all when the computer is turned on, make sure it's plugged in - a wire should connect somewhere
If neither of those work, you may just have to look into a replacement fan, at the least, or a new heatsink/fan assembly. Make sure you get one for AM3 (as Intel sockets - usually designated with a number like 775, 1136, etc. - are secured differently.) They can run from cheap to over $100.
Apr 22, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Does this computer supports windows 7?
If your computer has RAM memory more than 1 GB then you can install windows 7 onto it without any problem.
Thanks
Apr 05, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Cant find a motherbord manual to hookup power swtich for new case
Search on the Internet for your motherboard manufacturer's support section - Manuals can usually be downloaded for free, which will help you out.
Sep 07, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
I installed a AMD Phenom(tm) 9950 Quad-Core Processor which runs at a speed of 2.6 ghz but windows xp pro is only reading it at 1.3 ghz. I also have 4 gigs of ram but windows xp is only reading 2.75. The...
There seems to be some sort of incompatibility issue between your motherboard and the Phenom, or maybe some option is not enabled in the motherboard bios that windows is only sensing half of the GHz, like if the processor is only running 2 cores instead of 4.
About the memory diference, that same problem is because the 64bit difference. Unless you have a 64bit XP you won't see the full 4GB. Windows XP is limited to 3 or 3.5GB of ram it can use, you are showing 2.75 maybe because some video board is integrated in your motherboard and it may be borrowing an extra 0.25GB from the 3GB that are usable under windows XP 32bit OS.
Please comment what motherboard you have, since the cpu alone can't be blamed nor configured.
Jan 03, 2009 | AMD Phenom X4 9750 Quad Core Processor...
Gateway GM5664 Desktop PC Logo
163 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
