Question about Ricoh Aficio IS01 Flatbed Scanner
My cable that came with my ricoh is01 does not seem to be compatible with with my scanner and neither can I plug it into the pc.
  • Ricoh Master
  • 5,473 Answers
The Ricoh IS01 uses a SCSI 2 (50 pin) interface. It should look like the one here: http://www.amazon.com/Cables-Go-03564-SCSI-2-Cable/dp/B000051312 . There are SCSI to USB converters but I'm not sure if you need a specific version. (Scanners require bidirectional communication with the computer so there were few interfaces that required a special connection.)
Depending on your computer's OS, there may be other issues. (Some may not be compatible with Windows Vista or Win7, for example.) Drivers for some OS versions are available here: http://www.ricoh-usa.com/downloads/downloads.aspx . Search for the IS01 (no other information is needed)
I hope this helps.
Posted on Jan 01, 2011
RICOH Aficio 3045 Necessary HELP!!! Necessary
If you go into "user tools" is there a printer and scanner option there? If not the MFD does not have the print option.... If it does you need to program the IP address sub net and gateway. -Carl
Sep 18, 2016 | Ricoh Aficio Office Equipment & Supplies
What do I need to do in order to "Scan to Folder"?
GO TO THE PRINTERS WEB SITE AND SEE IF THEY HAVE A DOWNLOAD TO HELP YOU WITH YOU SITUATION.
Jun 13, 2014 | Ricoh Aficio SG 3100SNw - multifunction...
I can't get my Ricoh IS01 scanner to recognize the drivers that came with machine (windows 95 driver). I am running a windows xp system.
Microsoft drivers and installers have changed over time. The ISO1 drivers for XP are available here: http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/is01/is01en.htm . Click on the down arrow to download the one for XP and then double click on the exe file.
I hope this helps.
(NT or Win2K drivers can work under XP at times; Win95 drivers are less likely to work even in the compatibility mode.)
Nov 25, 2010 | Ricoh ISO1 400DPI Flatbed Scanner
I have my Ricoh Aficio MP 2000 connected to my computer via USB but my computer does not recognize the scanner. I can however print from my computer to the Ricoh. I tried installing the TWAIN driver,...
I have the same problem. I use the USB, my client is far far away from me, and is better for me install the Ricoh using the USB. But the scanner don't work.
Maybe the only way is using a ethernet cable, but i dont want to drive so far... :(
Oct 01, 2010 | Ricoh Aficio 1018 Printer
How do you clean the scanner or do routine maintenance to get it to operate better?
These are excellent and well built products with a very long high volume capability and unless in a very dirty environment should not need cleaning of internal optics or assemblies until after about 3 years or more. However the document feeder can get dirty, and the rollers and guides should be cleaned with a mild solution of soapy water, (a few drops of Palmolive Liquid Dish Soap are best); use a good glass cleaner on the scan class and also on the narrow glass view area used for the auto feeding copies. If it does not jam multiple stacks of copies up to about 40 pages of 20 pound bond, it is running just fine. Let me know if you have any further details needed.
Good Luck!
Aug 03, 2010 | Ricoh Aficio IS01 Flatbed Scanner
How to Link Scanner from ricoh aficio 1232c
Download Twain Driver from ricoh site and you can use any softwere that suports twain scaning i use microsoft scan that comes with office 2003
Oct 18, 2009 | Ricoh Aficio 1232C Color Copier
Image is Streched when scanned
Possible wear and tear. The image path movement must match the scan head one has to be 'stationery' in relation to the other- It seems that one element is slowing down. Is there a rate of travel adjustment to be made - check your manual
Aug 29, 2007 | Ricoh Aficio IS01 Flatbed Scanner
Ricoh Aficio IS01 Flatbed Scanner Logo
143 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
