Question about Nintendo Wii Console
Wii Signal is not found by TV - Nintendo Wii Console
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 364 Answers
I want to just make it clear to you, that you can repair the following problems at home with a good repair guide. There is no technical knowledge needed you simply do what you see on the step by step vids or the paper guide.
click here for your reference
Posted on Jan 05, 2011
  • 281 Answers
First check the basics:
1. make sure video cable from back of unit goes to inputs on back of TV, each color should match (yellow to yellow, white to white, red to red)
2. make sure unit has power cord, plugged in, turned on (blue light)
3. make sure TV is selected as the correct signal input, (many TV's have several inputs Input1, 2, 3, etc.) try them all. To change this look for "source" or "input" on your remote.
Posted on Jan 01, 2011
How do I fix Magnavox HDTV stuck in av after use of Wii?
If the Wii is not used, and if some other source is used, does the set still stay stuck??? If it stays stuck with the Wii connected, but not with some other device, then the fault is with the Wii and not the TV. Maybe there is something in the characteristics with the Wii output that is the cause...
If that input stays stuck with any source, when I used to do TV service there were a number of things that caused this. I had to sometimes change the input control IC (input matrix IC), and or, one or a few of the components associated with this IC. These components were identified by following the digital control signal paths with a digital scope and volt meter and using the schematic diagram as reference. Sometimes I found the main uPC (micro-controller) in the TV set was the cause because it was not properly sending the command for the input change.
The most basic thing you can check is if the remote is sending the proper remote command signal to the set. If you do not have a remote control signal analyzer you can try another remote such a universal remote control to compare.
May 01, 2014 | Sanyo DS31590 31" TV
Nintendo wii to lcd tv
you need a converter between the wii and lcd tv
Mar 30, 2008 | Nintendo Wii Console
No signal to tv from wii
I hope that what I am pretty sure is wrong (hardware failure)is not your problem.
1) Try hooking it up to another TV
2)Check physical connections: cables, and inputs on both TV, and wii. Lose and dirty connections are usually the problem.
3) You stated you unpluged everything. Did you wait ten minutes before plugging bower back in? Be sure output is what it is suppose to be using multi-meter.
4)Nintendo has software(code) embedded so that pirated software is always detected and blue screens the unit. There are geeks that have "workarounds" with SD cards, but I have found OEM games used in pawn shops for as little as $5 most for no more than $ 20. My point is if you used a copied game Unit is fried. I am on my 3rd wii, the 1st one when they first came out lasted 3yrs but had a ton of hrs, on it. The second I bought used for $100 at a pawn shop lasted almost 2 years, and the current one, used is almost 2yrs. old. paid $160 but got about 10 games and wireless controllers, new cables.
I hope your problem is just a connection or power adapter.
Nov 07, 2013 | Video Game Consoles & Games
When we turn to the tv to "av" we usually get signal for WII, but now it says "no signal"
Make sure your video connections are correct and make sure any external video selectors are set to the correct input. If the wii is connected directly to the AV input in the TV then check your resolution settings on the TV if possible. Try a known good wii audio/video cable to see if it has gone bad. If it still doesn't work after that then the audio video port on the back of the wii may have gone bad or the wii motherboard may have gone bad.
Jan 15, 2013 | Nintendo Wii Console
Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
Dec 29, 2009 | Nintendo Wii Console
How to set up a UK Wii for use in the US
This is because UK wii's use a PAL signal for video display. If your TV does not support the signal, it's always going to be black and white. You might need to try a different TV.
Aug 11, 2009 | Nintendo Wii Console
Installed a Wii to YPbPr1 port. display is B&W, no color. How do I get the display in color?
Unless the Wii is sending the video signal in component form, you have a case where the signals are not compatible. The Wii is sending "composite" and the TV is expecting component. With the composite signal the Y input, the result will be a B&W picture. Either set the Wii to send component or connect it to the composite input on the TV.
Dan
May 12, 2009 | Televison & Video
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Wii Console signal
you should make sure that the cords are plugged in correctly in both the wii and the tv. if not, you should try different cords and a different tv.
Oct 15, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
169 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
