Question about Acer Aspire 5315 Notebook
On powering up, I get a high pitched continuous beeping and can go no further.
  • 23 Answers
Try reseating the memory. Open up the memory compartment on the bottom of your laptop. Remove both (I assume you have two) and replace. Make sure each is seated snugly.
Posted on Jan 01, 2011
    Genius:
  • 1,288 Answers
Check ther are no stuck keys on the laptop. Power off, run the palm of your hand over the keyboard and see they all bounce back freely
M2n68-la beep codes
Whenever electronics devices give high pitched beep, it generall means a future failure . There could be reasons for the same.
1. Static built up on the motherboard
2. Conflict on the USB ports.
Troubleshooting 1 :
1. Diconnect all the wires from the tower, including the power cable. Press and hold the power button in the front to remove any static from the motherboard.
2. Check and try again the devices on the USB port.
Troubleshooting 2:
1. Check USB ports for damage , try connect the device to the back of the tower.
Troubleshooting 3
Clear the motherboard setting , use the link attached and see clearing the BIOS settings
Thanks for using fixya
Proton
Jul 07, 2012 | Computers & Internet
A long high pitched beep after turning on the cpu. what is the problem sires?
Welcome to Fixya
Beep codes usually tells us that there is something wrong with the computer. 1 long beep tells us that there is a problem with the video card or memory module. But this should accompany whit short beeps. Could you verify further how many beeps are you getting there. Here's the link for the beep codes for your reference.
Please let me know if you have further questions.
Thank you for using Fixya!
Feb 26, 2011 | Lenovo ThinkCentre A61 Desktop Sempron LE...
HP A6600f desktop, loud beep 18 secs off 10 sec, cylce repeats
The beep is a code to tell you what is wrong. POST - Power on Self Test. http://en.wikipedia.org/wiki/Power-on_self-test You can serach the web for more detail as well. Usually memory has popped loose or a connection is not seated fully.
Apr 24, 2010 | Computers & Internet
How would you know high limit thermostat is defective. need to know before ordering part
Hi, you'll need a ohm tester (multi-tester) you will have to remove / disconnect wires from hi-limit, in normal room temperature, place tester lead on terminals where you remove wires, if you get a beep/continuity, hi-limit is o/k, if no beep/continuity, hi-limit faulty, for further test you can heat up hi-limit, (oven) and check with tester, hi-limit switch off when temperature gets to high, and switch on when temperature drops, so at room temperature hi-limit should be on, (hear beep on tester), if there's no beep/continuity at room temperature, high-limit is faulty. disconnect power before doing any repairs, good luck.
Aug 29, 2009 | Dryers
High pitch screech w/no signal
is this a picture tube type of tv? big in back? If so, it could be the tube/circuit short.
If it flatpanel, it could be a bad capacitor in the DM or "Y" board or even possibly faulty power supply. Further testing will be necessary
Jul 22, 2009 | Polaroid FLM-3732 Television
Beeps
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
Jul 06, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Mar 04, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
High pitched whine
I have the same problem. Replaced the module and still a continous beep....
Dec 28, 2007 | GE 24 in. Profile PDW9880JSS Built-in...
Acer Aspire 5315 Notebook Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
