Question about Kenwood XXV-03A Mono 25th Anniversary Power Amp Car Audio Amplifier
In my display is says 3-03 when ever i plug in my rca cables and no sound comes out?
  • 15,935 Answers
From Page 7 of your manual... this is indicating a grounded speaker wire (blown voicecoil).
It has shut down to prevent damage. Disconnect the speaker wires from the amplifier and power on the amplifier again. If the error persists - you will need to have the amplifier repaired.
Check the voicecoils for proper imedance.
MANUAL LINK
Thanks!
Posted on Jan 01, 2011
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
Multiple rca cables plug-in
You need to get a device call a composite video switch box. You plug allof your devices in the inputs on the box and then the box uses cables to plug into the TV. You then just use the switch box to select the video sound you want to display. The switch boxes are available in manual and remote and you can get them from Amazon.com
I hope this helps,
BuddyMc
Sep 21, 2012 | Vizio L32 32 in. LCD HDTV
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
The jack plug dos not stay coneckteg the sound keeps going
From the basic info provided, I would assume you are using RCA cables to connect your sound. To fix the plug from coming undone, you can use a pair of pliers to gently squeeze the outside ring on the RCA cable. This may make it appear a little out of round, but when you reattach the cable, it will be a tight squish fit on the connector and will no longer come loose
Feb 28, 2011 | Daewoo Televison & Video
I need the wires to connect the surround sound. Any ideas where I might get them? And what are they called. They each have 2 wires and 2 holes to plug. thanks
almost all surround sound connectors are RCA cables. ask for any RCA cables. sometimes they come in pair or u can buy individual cables.
Apr 13, 2010 | Durabrand STS92 System
RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Jan 05, 2010 | RCA RT2380 Home Theatre System System
I have connected my macbook to the tv via VGA cable...i have the picture displayed, but the sound is still only coming out of the macbook speakers. How do i get the sound to come from the tv??
Connect the sound output (head phnone or line) of the laptop to the component input for sound on the TV. You will need an 1/8" plug to sterio RCA adapter to connect.
Oct 02, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Connect my laptop to tv with a sound
Your computer may have come with cables to do just that. If not, you have options:
For video, I would check your TV inputs to see if it has a VGA port, since that would be the easiest. You can also get VGA to RCA or S-Video converters online as well if your TV does not have a VGA port. Almost all TV's these days have RCA inputs.
For audio, you can get a headphone jack (3.5mm) to RCA converter.
If you can't find the converters at your local electronics store, just google VGA to RCA and headphone to RCA.
Once you have the necessary cables connected to your TV, your computer will recognize that it has been connected to an external video source. I'm not sure, but I think it is either key combination Fn+F6 or F7 to perform a monitor switch. You can also right-click on the desktop and select properties (or personalize in vista). Then switch to the settings tab (or Display settings in vista) and click on the alternate display.
May 03, 2009 | Sony VAIO VGN-FE550G Notebook
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Optical audio not working
i have this problem but i dont have a cable box, if i use rca's i get sound but optical cable nothing
Sep 03, 2007 | JVC RX-DV31SL Receiver
Kenwood XXV-03A Mono 25th Anniversary Power Amp Car Audio Amplifier Logo
71 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
