Question about Jack Lalanne Power Juicer 250 Watts
My food pusher is stuck. How can i get it unstuck?
  • mylesinfront Jan 01, 2011
    What exactly is stuck?
I NEED A FOOD PUSHER FROR BREVILLE MODEL
Check with a local appliance parts supplier.
May 06, 2016 | Breville Juicers
Pusher stuck in fusion juicer
May not be repairable if pusher is distorted or damaged. If jammed with a foreign body, need to carefully pry apart and clean out. Find a handy person and offer a fine juice meal.
Nov 25, 2014 | Juicers
I need a food pusher for my Krups juice extractor model #267
You\'re in luck! Go to the Krups Online Store (krupsonlinestore.com). They have a pusher KRW MS-4952202. It\'s clear plastic and the top is a bit different from that of the original white pusher, but it fits into the feed tube exactly right and has the same penetration. It lists for $6.99. I had to pay $6.95 for handling and shipping.
Feb 05, 2011 | Krups Juice Extractor
The pusher to push the food into the blade is coming into contact
The blade maybe was not screwed in right. Screw out the blade using the blade tool and screw it back again making sure it is screwed in and fitted in right. Do not tighten too much. It breaks easily.
Jul 10, 2009 | Jack Lalanne Power Juicer 250 Watts
Pusher is too long
Buy a file or sandpaper from a hardware and file off the part that touches the blade. I've done this no prob.
Jan 08, 2009 | Jack Lalanne Power Juicer 250 Watts
Pusher won't come out
Hi,my name is patricia ,and i found a solution,first the black button .the black vise grip put it in the blade while the blade is still in turn the black vise grip to the left while still in the blade keep turning to the left and the blade will come off of the black button.the black button do not come off or up.When you put food in but smaller pieces in and have all your pieces near you so you can continue to drop in in the processer while running it and can slowly put the long tube in to keep food from splashing do it slowly .hope that help
Aug 27, 2008 | Jack Lalanne Power Juicer (Stainless...
Jack Lalanne's Power Juicer Pusher Stuck
It will take two people to get the Lalanne Juicer pusher unstuck. We wrapped a sock inside a sock and put the top part of a hammer in the sock, then I lifted the large white part up while he hammered the pusher out. It took 6 hits and voila!
May 17, 2008 | Jack Lalanne Power Juicer (Stainless...
Jack Lalanne Power Juicer 250 Watts Logo
60 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
dflynn2204
Level 1 Expert
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
