Question about Harman Kardon AVR 65 Receiver
Harman kardon avr 65 in protect mode. I have redone speaker wires and its still in protect mode. how do I reset the receiver to factory settings?
5 Suggested Answers
  • 8 Answers
SOURCE: Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Do you get an indication on the display where the point of failure might be? It would show up on the LCD speaker diagrams just before shutting off.
Posted on Dec 28, 2007
  • 236 Answers
SOURCE: Harman Kardon AVR 245 Receiver PROTECT Error Message/Shutting Down All Equipment
could be your receiver only, it has tripped due to discrepancy on the output stage of your amp. that cracking sound in one of your speakers could have caused the trouble. it is possibly shorted. but in your case it could have damaged already the amp that;s why it would not turn on. normally it will first trip, turn on then turns off. but to stay off and not to turn on again is major problem of the amp. or maybe it emanated from miscabling, probably the ceiling speakers got connected to a high output or main amp. but try removing all speakers first then turn the unit on. see if it does power up.
Posted on May 22, 2008
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
SOURCE: My Harman Kardon AVR 330 is locked. Can't unlock
youtube
myspace
facebook
Posted on Feb 12, 2010
Harmankardon avr 65 reciber ** protect** on my avr 65 reciber display
It's a DC couplage problem ... you can't do any one if you're not professional electronician ... and this is want to schemas and experience.
So you wanna take help from Harman/Kardon technic services... :S
Oct 31, 2015 | Harman Kardon AVR 65 Receiver
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
No Memory Stotred in Harman Kardon AVR 65
You have a memory cap ,usally located on the front display,that is most likely defective.measure voltage on cap with unit off should measure at least 3-5 volts
Apr 10, 2010 | Harman Kardon AVR 35 Receiver
I recently moved so now connecting my Harman Kardon AVR125 display comes up but no sound from speakers. The only thing i notice strange is "HP" written where the preset station number comes up besides the...
Try resetting the system. In standby mode, press and hold the tone button for at least 3 seconds. The message RESET will flash. All turner and system setup info will have to be redone....
Mar 28, 2010 | Harman Kardon AVR 125 Receiver
Protect flashing on screen
Output amp needs repair or you have shorted speaker wire or bad speaker. Disconnect speakers. If still going into protect mode after turning reciever back on then have amp repaired.
Nov 20, 2009 | Harman Kardon AVR 65 Receiver
No audio from Harman Kardon AVR 7000
Incorrect polarity between receiver and speaker will not damage receiver however unmatched impedance speakers can damage amplifier section of receiver.
Please check connection cables in receiver and if receiver does not shut off in protection mode then it could be connection cable broken or some dry / cold solder joints on circuit boards in receiver.
Re-soldering of cold solder joints is job of qualified tech.
Sep 14, 2009 | Harman Kardon AVR 7000
My Harman Kardon receiver ( AVR 225) displays "protect" and shuts off when I try to play anything (tape, CD, FM/AM). I unplugged receiver and reset it several times. The sam "protect" comes again.
I used the live chat and the problem was resolved.
Usually the problem are strands of speaker wires which cause shorting and protection shuts off the receiver in order to prevent damage. There was one speaker that I repositioned recently which was causing shorting. I twisted the wires and tightened them in place and my receiver has been working w/o a glitch. I was lucky that I did not have to check all the wire strands on the receiver and all the speakers.
Problem solved and I learned valuable lesson.
Dec 27, 2008 | Harman Kardon AVR 130 Receiver
I have a Harman Kardon AVR 235 Receiver that go's into Protect
To avoid making the avr go into protect mode when you power up your Hafler 4000 that is connected in the avr's pre-out, you must power up the set up in the correct sequence.
1. Turn off your avr
2. Connect Hafler 4000 to the avr's pre-out it it is not yet connected
3. Turn on your Hafler 4000. The avr will not go into protect mode becasue of the transients from the Hafler because it is still not powered on.
4. Turn on you avr. There should be no more transients from the Hafler at this stage unless it is not functioning correctly, so the avr shouldno longer go into protect mode.
Dec 08, 2008 | Harman Kardon AVR 235 Receiver
Harman Kardon AVR35
check that your speaker wires are connected properly, and none of the wires are touching. if this dosent work hold the sur mode and tune mode at the same time with the unit off(in stand by mode) and this will reset the receiver
Jun 04, 2007 | Harman Kardon AVR 55 Receiver
Harman Kardon AVR 65 Receiver Logo
315 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
