Question about Sub-Zero 642
Frost on the inside of the refrigerator - Sub-Zero 642
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
You unit is a dual system, your refrigerator side maybe low on freon, or the compressor is failing.and if you are lucky you may have a defective fan.
The good/bad news is the freezer side has its own compressor. so it will stay cold if the refrigerator side fails...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
  • grandma4557 Aug 04, 2011
    3 years ago I got An amana w/freezer drawer at the bottom....My son wedged it in the spot even tho it didn't fit....this summer the stuff on the top shelf froze and the side of the refrig was all sweaty......My neighbor got it out of there by putting straps under the front legs ---lifting it up and pulled it out.......the side of the wall was black mold----not sure about the type but I had been ill with symptoms much like a cold---sinus infection---so for a month I took antibiotics for 2 weeks
    and every cough and cold remedy I could find. now I take prednisone for water behind eardrums...my hearing diminished..WHAT shall I do now w/refrigerator???
New frigidaire refrigerator frost in back of freezer
Is it on the inside or outside of the freezer? I assume inside.
Be sure the air flow from the fan is not blocked.
Oct 03, 2012 | Frigidaire Refrigerators
Jenn air side by side JCD2389GES ****** still won
If there are only a few rows producing cold from the freezer it may be a Freon leak. Remove the rear panel inside the back wall of your freezer and examine the frost pattern. When a refrigerator has enough Freon it will have the complete evaporator covered with frost. Here is a photo of what a frost pattern looks like with only a few rows.
Frost Pattern Only Two Rows
Click photo to enlarge
Unfortunately if this is what you see with evaporator exposed you will be better off shopping for a new replacement refrigerator because the cost to repair is just not worth the expense to have someone repair your refrigerator. If you have questions please ask, Thanks Sea Breeze
Sep 11, 2012 | Jenn-Air JCD2389G Side by Side...
Samsung french door freezer gets lots of frost inside - we've replaced the gasket but still get frost
Could be the rail slides not closeing correctly keeping door open slightly. Also they have made a new stronger set of rails to be used. Try going to the Samsung web site for tech info our recalls for that unit
Aug 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
I HAVE A KENMORE COLDSPOT 106.56542400 MODEL.THE REFRIGERATOR DOES NOT GET COLD AND BOTTOM FREEZOR SECTION FROSTS UP.IF I UNPLUG REFRIGERATOR FOR A DAY,EVERYTHING WORKS OK FOR ABOUT 2 WEEKS AND THEN...
We had the same thing and the problem was the frost sensor on the coils inside the freezer. It is behind the metal cover that gets all frosted up. When it works it senses frost on the coil and tells the control panel to activate the defrost wire which heats up the space melting any frost and then shuts off.
Our issue was the frost sensor but it could also be the heating element or the control panel. Anything in that little system.
Sep 21, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Frost on the inside of the freezer
Your heating element is broken disfunctioning, If you can't find part locally let us know
Dec 03, 2009 | GE GSH22KGM Side by Side Refrigerator
Frost forms on top of food in my freezer (top of refrigerator)...even inside sealed bags of items like microwave Stouffer's, etc. Sometimes up to 1/4" thick! No frost on inside of freezer though. ?????
This excess frosting can be caused by leaky door gaskets, frequent door opening, dispenser door not closing good, anywhere air can get in. Gaskets should hold a dollar bill sung all the way around both doors.
Sep 24, 2009 | Amana ABB1927DE Bottom Freezer...
Does not cool. Compressor is running, fans are
Hi, Look in the freezer section and see if there is frost building up on the rear inside panel. If the is frost, on of three parts are bad in the automatic defrost.
If there is no frost, the compressor might be weak and not pumping the coolant as strong as it should.
Remove the rear inside panel in the freezer sevtion and see if the evaporator is frosting at all.
Please let me know what you find so I can assist you further with this issue.
Vic
Jun 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water keeps dripping under the fridge.
In a frost-free refrigerator/freezer the frost that would normally accumulate on the inside wall of the freezer is removed by heaters imbedded in the freezer's walls. Periodically these heaters are turn on to melt the frost which then exits the freezer as liquid water through a drain in bottom. This water accumulated in a pan underneath the refrigerator and is supposed to be removed by evaporation. If the flow of melted frost from the freezer is greater than the evaporation rate in the pan then the pan will overflow and you will get a pool of water on your floor. A bad seal on the freezer door will allow more frost to form inside. Also if you leave the freezer door open a lot you will accumulate more frost. The evaporation rate in the pan can be affected by the ventilation around it. If the vents on the bottom of your refrigerator are clogged with dust it will decrease the evaporate rate in the pan. In addition, many refrigerators have a fan the pulls air around the pan. If this fan has stopped working the evaporation rate in the pan will also decrease.
May 11, 2009 | Refrigerators
Freezer not freezing
when the freezer is not freezing, check the fan and fan motor in the freezer section. It should be running when the compressor is running. Check for frost. If you see frost on the rear inside panel, the frost is usually about 3 in. thick on the inside. Check and make sure the fan next to the compressor is running, if your's has one. It will run when the compressor is running. Check for gaps in your door gasket. If there is no frost, both fans are running, compressor is running, and no gaps, and your coils outside the refrigerator are clean, it doesn't sound good.
May 04, 2009 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
337 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
