Question about OWI Robotic Arm Edge Kit
Need page 15 of assembly manual owi-535 robotic
  • 17,970 Answers
Hi Robert:
I suggest check this link: OWI-535 Robotic Arm Edge
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Dec 14, 2011
How do I change the sprocket on my Jonsered 621 chainsaw?
the sprocket is part of the centrifugal clutch assembly
go google and type in ---workshop manual for jonsered chain saws and there are pages of manuals
I opened one page named jonsered 2036 workshop manual --pdf download and it shows how to work on the chainsaw and includes other models in the procedures
that site is www.manualslib.com>brands>jonsered manuals> chainsaws>2036
Sep 26, 2015 | Garden
Fuel system parts for 1991 535 virago under tank fuel pump
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Amazon com CNT Fuel Pump for Yamaha XV535 Virago 1988 2003 Fuel Pump...
How to test fuel pump Yamaha Virago 535
Yamaha XV 535 DX Virago Service Manual
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-16_110.pdf
Jan 28, 2013 | 1991 Yamaha XV 535 Virago DX
Incorrect parts from 3 in 1 robot transformer solar kit
call where you got the kit from and ask them what can be done
May 25, 2017 | Elenco Electronics Elenco OWI-MSK614 T3...
Instruction manual for robotic arm
Building the gearboxes is a pain using the instructions. instead use the 2 strait plastic bit with 2 screw holes in each end. put the nuts and screws rough the holes and use it to hold the nuts in place while closing up the gear box case. No more will the moter magnet pull it out nor will they be the wrong way up or fall out. Now to get my arduino and moter shield to control the arm....
Dec 14, 2011 | OWI Robotic Arm Edge Kit
1989 virago 535 i have a petrol leak from the back over flow pipe on the carb & when fired up the revs go straight up any suggestions
Hi, Gregj_sillen and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://viragotech.com/newtech/535%20runs%20for%20a%20while%20then%20dies%20(SOLVED).htm
Virago XV535 carb
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Jun 29, 2010 | 1988 Yamaha XV 535 Virago DX
535 series - just put in new battery - does not work - just spins around in circles and tries to back up - then beeps nine times (bumper?) Won't dock.
Hey
Please look for other same problem posted here ;-)
You are probably facing a bumper sensor issue.
Try to clean the bumper first and if this goes on, either call iRobot service, or
take a look at this page for the step by step 9 beep fix.
Have fun
Avi
Jan 23, 2010 | iRobot Roomba 500 Series Virtual Wall...
Robotic Arm Edge not working properly
I noticed the same problem on my pin 8 - however it wasn't the issue. I had the exact same problem and emailed OWI for tech support. The problem was with the battery connector plate. The "nipple" was facing out (away from the battery) rather than in so there was no power getting to the one side. You need to take off the arm and the top two round plates, then you can slide the connector plate out, turn it around and slide it back in. Works now! (This is step 16 in the instruction booklet.)
Dec 26, 2009 | OWI Robotic Arm Edge Kit
OWI Robotic Arm Edge Kit Logo
168 people viewed this question
Top OWI Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an OWI Toy Expert? Answer questions, earn points and help others
