Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
DeLonghi Magnifca...had it for 2 years with no issues. Upon pressing an espresso or long shot, it grinds but does not pour. It reads "LESS COFFEE". The infuser appears crooked ...
  • 452 Answers
Could have grinder problem .... bsc appliances 07779933829 postal service too.
Posted on Feb 26, 2011
I have a Delonghi magnifica s plus and it won't grind the beans and as a fault message saying less coffee
Try less beans and see if it works. If still nada it may be an issue with the motor not working and grinding the beans. If there are motor brushes they may be worn and render the motor inert.
Sep 04, 2017 | DeLonghi Coffee Makers & Espresso Machines
What are all the possible causes of the delongi magnifca alert esclamation mark to stay on please
if all the trays are in place and door is closed then you have a component failure inside the machine and it willl need a tech to check and replace. it is beyond home repairers
Oct 30, 2014 | DeLonghi Magnifica Coffee Makers &...
Coffee grinded but no coffee coming through
Got water in unit? is it heating water? is there a blocked pipe so no water come through? for last 2 remove coffee handle push button to pour coffee and see if water comes out and if it is steaming hot.watch ,don't touch hot water .
Sep 06, 2014 | DeLonghi Esclusivo Gran Dama EASM6600...
Espresso shots pour very slow for both the single and double shots.
Did you try adjusting the group head screw? And/or cleaning and checking the valve in the group head? Good visuals and instructions here: https://myprojectsandmods.wordpress.com/2014/10/27/delonghi-ec702-espresso-machine-no-water-flow-fix/
Feb 03, 2014 | DeLonghi EC702
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Double shot button runs so slow you thinkit is going to stop
hi, maybe your grind is set too fine. If the grind is too fine, the water cant flow through. If your single shot flows ok, then id make the grind a bit coarser. Have you changed the blend. All blends are different. If you have not changed anything, then your pump pressure could be low. There is no adjustment for the pump. Replace pump if pressure is low.
Oct 07, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My delight magnifica is now grinding too much coffee causing lots of excess falling into machine. How to I adjust the grinding time?
I had this same problem and discussed it with DeLonghi customer service. My machine was grinding 20 seconds for a double shot and ground coffee was coming out of the top and spilling over inside what a mess! DeLonghi thought it was potentially a problem with the control board - grinding time too long - which is an expensive repair. I also called the local factory-authorized service and described the same problem. They asked what kind of beans I was using and I answered Starbucks espresso. They said that Starbucks is too oily, clogs the machine, and that I should try beans that are lighter. I also checked with an engineer who used to work at Starbucks and he made the same guess. I tried an Italian roast espresso from a local market and it worked! I've had no problems since. The new beans cleaned out the oils and I'm getting great shots. This is a good machine, but is best making single shots.
Jun 11, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Mar 06, 2008 | DeLonghi EC140 Espresso Machine
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
555 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
