Question about Microwave Ovens
One of the off/on switches broke off. how can I get it fixed, or get a replacement?
  • 2 more comments
  • Barrett Palumbo
    Barrett Palumbo Jan 01, 2011
    Sorry to read about your issues.
    But you really need to give us the make and model, of your unit. It kinda helps us to help you. and a more detailed explanation, of whats is going on.. which switches
  • Rhyanna
    Rhyanna Jan 01, 2011
    Hi I thought I had. Its a Salton DS16, with dual coffee pots, burners, etc. the left on/off switch broke off making it unuseable as there isn't a way to turn it on.
  • Barrett Palumbo
    you had placed this under microwaves, i am a tech for that.. you may want to re list your problem, under the coffee maker section, with the correct model number
  • Rhyanna
    Rhyanna Jan 02, 2011
    thanks for the help. Since this is a coffee maker, I went and listed my question there instead.
  • Microwave Ovens Master
  • 9,098 Answers
See:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 02, 2011
GE SPACEMAKER MICROWAVE OVEN MODEL J VM64 003 LIGHT SWITCH BROKE HOW DO I REPLACE IT?
Unfortunately it appears none of these parts are avail anymore. The physical buttons, key panel assy, touch pad support are no longer available. The smart board (WB27X5239) seems to floating around, but this does not appear to contain either of the 2 buttons or switches as part of it's assembly. Pleazer Appliance..
Jan 11, 2015 | GE Microwave Ovens
How do I fix a Kitchenaid microwave door latch?
remove broken switch & replace new one w/c you can easily buy from any electronic store or Radio Shack...
Jul 21, 2014 | KitchenAid Microwave Ovens
Buttons for fan & light on smh9207st samsung microwave collapsed when pushed
I had same problem a few days ago. I decided to use my own skills to troubleshoot this and determine if it would worth repairing or if I should get a new unit. My microwave is only 2 years old. After I found a solution I thought it would be a good idea to post what i did to fix this...or rather work around this problem.
What I discovered was that it is the switch tab which was broken. for the Vent fan and the light switches. The problem manifested over a period of few weeks when i had to apply increasing pressure to activate these switches and finally one day they broke and went all the way in and i could not reach it.
I downloaded a Service manual online and got instructions on how to access the inside of the switch compartment. ( i'll try to attach pictures).
Basically what i found ( as stated by earlier posts) that the flimsy plastic tab broke. I figured gluing this or buying a replacement unit will only solve my problem for a few days as this is likely to break again. Basically there is no support at the back of the circuit board. so if you push had you are likely to break whatever is holding these switches in place. Just bad design.
So i removed those buttons completely. Added a thick padding using some non conduction packing material, so that any amount of pushing will not mode the circuit board from its place. The base where the actual circuit board has the round push button which is accessible from the outside. I can push a small plastic stick and operate these. So it's not pretty but it works fine
Apr 11, 2012 | Microwave Ovens
Inner Bootom Door Hinge Broke off...since then it will not turn on...Will that prevent microwave from functioning?
You probably mean the door LATCH broke off. Yes, that will prevent your oven from operating. The door latches operate switches inside to indicate that the door is closed. If the control board doesn't see the right switch settings, it thinks the door is open and won't allow cooking. Replacement latches are available, but you should check with a professional shop to do the repair. If door repairs aren't done correctly, there is a chance of microwave leakage and an unsafe oven.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
We take turns replacing microwave ovens where I work. The latest one, a GE JES1358WL, stopped working after opening the door while running on a one-push (1 minute) start setting, and the control panel is...
Sounds like part of the peg broke off and is left inside the recepter slot area where the sensor switch is. If it is the lower door plastic hook thing (inside bottom) that broke off, it is possible to re-attatch it to the door if you save the broken piece. Drill a small hole the size of a small wire or nail you have lying around to make a splint - Cut the nail or wire to about 1/2" to use it as a hidden "bone" or skeletal support inside the broken plastic. Glue the nail half way into the broken plastic using modelers glue. Closely align the nail peg to where the plastic broke off and mark it for drilling. Drill carefully making sure you are centered so that your wire "bone" will allow proper alignment of your plastic. Insert the pinned piece into the newly drilled hole checking for alignment, if it looks close enough you can glue it in place and you should have a strong enough repair. Dangerous to use a wooden peg to fool the internal switch. As it will be running even when the door is open and you don't want to get zapped.
Nov 04, 2010 | GE JE1235 Microwave Oven
The door latch broke, and I can't get the door open, or the food that was in there before the latch broke!!!
Remove the cover --- you shuld be able to release the lock from withinthe cabinet.
While you are there, you may want to replace the door safety interlock switch(s)
You may have to disassemble the door to get the latch fixed.
Oct 19, 2009 | Microwave Ovens
No power to oven after removing light bulb
What happend is that when the bulb broke the filiments touched (shorted out) and caused the reset switch on the unit to set>>>you need to find the reset button on this unit, look at your service manual. Additionally on some units there is a fused link internally, that may have blown>>>>both are an easy fix, so dont throw it out.
Good luck,
Geodesy
Sep 22, 2009 | LG Over-the-Range Microwave
Magic Chef door switch broke
Get the model from inside the microwave door and go to the link below. They have about anything for everything. Should be pretty easy to fix. Hope this helped.
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Mar 14, 2009 | Magic Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
