Question about Samsung 24.6 Cu. Ft. 4-Door Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Hello, There is a bright pink light that has come on in the Fresh Select Zone. It is a small rectangle pink shape with a tear drop shape underneath it. I called Samsung and they told me it was the water filter change light. We put a new water filter in, and the pink light is still there. I also disconnected the refrigerator for about an hour and cleaned it out. When I plugged it back up, the pink light continued to stay on. Please advise.
SOURCE: Low water flow from the water dispenser
Try to check the water really
Posted on Jan 12, 2008
SOURCE: Samsung Refrigerator
I have a RS2544SL side by side Samsung with a defrost sensor failure light upon a plug-in reboot, according to the service manual, which I purchase from Samsung so that I could help a local service provider unsuccessfully fix the unit.
The unit was less than 3 years old when I started having problems. The freezer side works although the unit will not re-boot following a power outage because is hangs-up on the defrost sensor flashing light on the front display.
Samsung service providers have stopped working on Samsung refrigerators and Samsung would not suppor the repair.
I had an independent service provider install a new defrost sensor but the reboot-pluging program still hangs-up at the defrost sensor despite a newly installe defrost sensor from Samsung.
The freezer side continues to work well and problems continue with the refrigerator side. The unit continues to fail during power-outages because it hangs-up on the warning light. I by-pass by holding both power freeze and power refrigerator buttons for 10 second as described in the service manual. After by-passing the warning light, the performance of the refrigeration side continues to be unreliable.
What is my next step to get my relatively new Samsung side-by-side refrigerator fixed, since Samsung will not back their warranty and Costco where I bought the unit also will not backup the warranty and purchase.
Posted on Jun 11, 2008
  • 111 Answers
SOURCE: Water Filter light still red after new filter installed
You have to reset the light by pressing and holding the touch pad for 3-5 seconds. It doesn't reset on its own when you replace the filter
Posted on Dec 19, 2008
SOURCE: Samsung Quattro-Cooling RM255LABP Freezer at +20F
orrixcreek i have the same problem. how do you go into the samsung diagnostic? i pressed different buttons at the same time and they're giving me gibberish i dont understand. which specific buttons to press and what exactly do the codes mean? i called samsung and they told me the fridge was probably in "demo mode" that is used on the sales floor and they had me pressed the two left buttons for 6 seconds and a bleep occurred and the LCD went dim. it really didnt fix the problem.
Posted on Jul 20, 2009
SOURCE: Water is leaking inside my
It maybe need some maintenance like cleaning the filter on the bottom, also check the position of the fridge it needs to lean backwards a little bit.
Posted on Feb 28, 2011
Testimonial: "Very helpful :-) will give it ago. Thank You :-)"
Colors are not true. The main color is pink and various versions of pink. Can anyone help me?
Probably a blocked printhead.
Try a small test print - make a small graphic using something like PAINT. Make small filled colour rectangles in each of the colours that this printer has cartridges. Don't make them large rectangles - no need, just wastes ink.
When you print this, you'll soon see which parts of the printhead are clogged.
If the printer has been stood unused for a while, this is a common problem.
Clogged printheads can SOMETIMES be cleaned - but it's not guaranteed. Most Epson printers have fixed printheads, so unclogging is more difficult than printers where the head(s) are removeable.
You'll find lots of info on unblocking printheads on the Internet, just search.
Oct 04, 2013 | Epson Stylus Multifunction Inkjet Printer/...
I have light that is on the dash. it looks like a battery witha fan in it what does it mean
It looks like a rectangle shaped battery and has something like a fan on it? Could that be the `plus' sign?
It usually means your charging circuit has a problem.Check the voltage across the battery......Auto Zone or Advance Auto will check it for free. don-ohio
Feb 13, 2012 | 1999 Mercury Cougar
I lent my tiger shark to my sister who has a kidney shaped pool, mine is rectangle. Is any reprogramming required since the pool shapes are different?
No. The unit 'learns' the pool based upon time recorded in the horizontal and vertical positions while cleaning. It will work, although perhaps not as well as in a rectangle-shaped pool, without any further action than dropping it in and powering it up.
John
Sep 05, 2011 | Aqua Vac Tiger Shark
My computor will not fill in a colour in autoshape I have goone to format and fill and still nothing?
ok try this and be patient, goto auto shape and i want you to select callouts, only because you can make it bigger and you can see how it is done. When the object is on your screen. look at the top of the rectangle. you will see a green dot below the dot is a sort of dotted rectangle around your call out. now click on the shaded area below the green dot, a window opens if done right the drop down has cut at top and hyperlink at bottom. I want you to select format auto shape when that opens look at the top of the popup you will see "fill" and a line below it that lets you select the color, select a color and your call out will be colored in as that shade.
keep trying untill you get the pull down i told you of, now if you miss you will see one with just 3 items on it click out and try again.
Mel
Sep 21, 2010 | Microsoft Word 2003 for PC
WHAT DOES THE TOP TEAR DROP SHAPED BUTTON MEAN WHEN IT IS FLASHING ON A HP DESKJET 3820
The flashing teardrop light indicates your ink is about out.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | HP DeskJet 3820 InkJet Printer
I have a Mitsubishi Eclipse 2000 Gt. I recently been having problems with the right headlight. I thought it it went out. So i went to auto zone and bought a new bulb. But it still won't turn on. So i tried...
Did you check the socket that bulb plugs into.I hav seen where they melt for, the hat produced by the bulb.If that isnt the issue,I would suspect the headlight switch.But first stick to basics.Check all the fuses.
Dec 12, 2009 | 2000 Mitsubishi Eclipse GT
Racheting Noise and not working
could be a bad cam. take off the button on top of the agitator. there should be a cam assembly underneath. they are just little plastic tear drop shaped objects that wear out quickly and need to be replaced occasionally.
Oct 10, 2009 | Kenmore Washing Machines
2 inches of water every time it rains only on my passenger side
Water is probably from the fresh air intake located just under the right plastic cowl (lower windshield reveal molding). We see this often in our shop. To access the fresh air intake, remove the right windshield wiper and then remove the screws fastening the cowl to the car body. Remove the right cowl. Just above the rectangle shaped fresh air intake (& cabin filter) should be a bulb shaped strip (approx 12" long). All too often, this strip comes off and no longer diverts water. Glue the strip back onto the firewall above the fresh air intake using weatherstrip adhesive. Reattach parts that you removed and now the water should be diverted to either (or both) side(s) of the cabin filter. Good luck
Oct 06, 2009 | 2003 Chevrolet Impala
Crop the photo in diffeent shaps like heart.
The crop tool will not let you crop in shapes like elements cookie cutter tool will. However, there is a work around to do what you want to do which indecently is the same as you would have to do in Photoshop CS4.
1. Create a new document file or press Ctrl + N.
2. Open an image you want to crop.
3. Press Ctrl + A then Ctrl + C to copy the image.
4. Select the new document file you created and press Ctrl + V to paste the new image in a new layer.
5. Select the Rectangle tool or press U for the hotkey.
6. Move the mouse over to the Rectangle Tool and hold down the left mouse button and select Custom Shape Tool.
7. At the top of the menu you will see a Shape: icon with a pull down option. Left Click on the arrow to expand the window to select the shape you want. If you want more shapes to choose from when the shape window is displayed click on the arrowhead with a circle around it and select a new library or all.
8. Use the mouse to draw the shape to the size and location you desire.
9. The shape will be in a new layer with a mask which will cover the image. Hold down the Ctrl key and left click on the Shape 1 layer in the layer window. This will mask the shape and only the shape.
10. Press Ctrl +Shift + I to invert the mask selection.
11. Use the Select pull down menu to Feather, Modify, Contract, Expand and Border if you want apply those effects around the edge of the mask.
12. In the Layer window click on the eye next to the Shape 1 layer to hide the image.
13. Select the image layer you want to crop and press delete which will delete everything outside the custom shape you created.
14. Do not forget you can right click on the image layer and select Blending Option to add drop shadows and other special effects for the cropped shape.
Jun 05, 2009 | Adobe Photoshop 7.0 for PC
Samsung 24.6 Cu. Ft. 4-Door Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
138 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
