Question about AOC Monitor
When computer is turned on monitor flicks on and off . i then have to turn it on and off and eventually after about 10 minutes the monitor stays on
    Sergeant:
    Novelist:
  • 179 Answers
This could be more than one issue, but the first I would approach would be the power supply for the monitor. I'm assuming the monitor you're referring to is an LCD with a separate power supply. If the power supply is failing, it would cause this sort of problem. Check your monitor's documentation to see how many volts are required, and then use a multimeter to check the output voltage of your power supply. If it isn't steady, or if it's below spec, you need another power supply.
It could also be the connector cable from the screen to the computer, but if the cable isn't being moved around I would not expect that to be the issue.
Hope that's helpful.
Posted on Jan 01, 2011
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
Cannot get light to go on and then off at programmed time. Stays on. At cottage with no neighbours or ambient light. Installed professionally, not by myself. Frustrated many efforts before contacting...
Light stays on all the time: Turn power to light off. Wait 10 seconds. Turn power back on.
Typical option on motion lights: Quick power flick -- light stays on. Slow power flick -- light goes into motion sensing mode.
Hopefully the professional installer gave you a switch.
Jun 01, 2011 | Heath Zenith SL-5318-WH Dual Brite Motion...
Monitor won't stay turned on. You push the on button and it flicks on and then immediately off. Help!
The possible problem of your monitor is may be cold solder, bloated elec. capacitor or defective lcd panel. If you found that bloated capacitor replace it and resolder all pins of inverter area. Defective lcd panel could cause of display flicks then immediately off.
Sep 30, 2010 | Samsung SyncMaster 203B LCD Monitor
When turning on my monitor - the blue light is on
This could mean that you video card is bad or going bad. Also that the monitor is going out too. Its one or the other.Try to plug the monitor into another computer to test it first. It will give you an idea where to start. then move to the video card.
Feb 15, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Screen STAYS BLANK
check your system unit to make sure the problem is not from the system unit
the signal stage and cable is more likely to have faults contact a local technician for confirmation
Nov 27, 2007 | Star Logic 17" LCD Monitor
Philps LCD Monitor Won't turn on Straight away
That is definitely a problem with the monitor...if its under warranty have it replaced...if not...start looking for a replacement it hardly ever is worth it to have them repaired (shipping, parts, labor is usually a little less than a new monitor). Sorry
Aug 28, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
53 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
