By Gary10 - usenet poster
Recently moved----house has Jenn-Air slide in range mfg 16 years ago---no
idea how many years in use, but stove doesn't heat properly---will heat but
not hot enough. Don't want to spend a bundle on it since it's so old. Only
thing I can think of is low current. Could a breaker cause this? Or maybe
the elements could be defective. Any ideas???
Web
www2.netdoor.com/~woodyweb/index.html
1 Other User Has The Same Problem
Comment by tnxtian, posted on Apr 26, 2008
My Jenn Air Electric Range Model MH1140XMB-1 starts beeping then the F7 code appears. What does this code mean?
Best Solution
posted on Aug 11, 2005
pawa - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I had a Jenn-Air of the same vintage (I don't know where they got their
reputation for quality). I found two causes of low or no heating:
1. The elements weren't firmly seated - sometimes I could fix it by
pulling the elements out and reseating them. Spreading the two contacts
of the element and/or wiggling would often fix it.
2. I also found that the flat plug contacts for the two-burner modules
(the whole assemebly lifts out) had arced and become pitted. On one, I
was able to fix it by filing it smooth and then sanding with carbide
paper. The other was too far gone, and I had to replace the plug and the
socket it plugged into.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Jenn-Air SVE47100 Slide-In Electric
Email this problem
Email this problem
Can you Help with these Kitchen Ranges problems?
Jenn-Air SVE47100 Slide-In Electric Kitchen...
downdraft
downdraft
Hello, I have had my Jennair... Answer This...
F1 reading
F1 reading
Used self clean, after finished... Answer This...
Jenn Air Electric Range...
The touchpad is not doing... Answer This...
SVE47100B Jenn-Air Slide-In...
I'm trying to find the specs... Answer This...
hose size and type
hose size and type
I recently purchased e33658... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
Find Parts
