Question about Vacuums
I have a very old Soundesign Ultrasonic Humidifier. Model 1866. I need a water tank cap. This cap has a plastic pin in the middle of it as well as a rubber gasket type thing, this helps control the flow of the water. Can anyone recommend a substitute? Thanks Abbey
Just realize its an old post. just throwing mine out i would have sent u the cap. mine stopped shooting mist out cap is good oh well. linda c
Posted on Apr 23, 2013
reddevil6
  • 1673 Answers
SOURCE: Hoover SteamVac Model F6056-900 SteamVac/SpinScrub.
There are 2 filters, make sure they are clean, one is on the tank lid, the other is from the bottom, it is red, pull it out and clean it. If yours has a foam filter on the tank lid covering the yellow ball, make sure there is at least a 1/4 in. gap from the top. Also make sure that the lid in on and secured tightly.
Posted on May 26, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell Quicksteamer Powerbrush, modele 2080
There is a gasket on the cap, part #2035541 , gasket will come with the new cap.
Posted on Aug 10, 2008
  • 37 Answers
SOURCE: The water won't stay in the tank...
you will have to replace the complete water tank assy. i have tried without any luck to get this valve to stay in place.
Posted on Oct 01, 2008
  • 85 Answers
SOURCE: water pours out from the clean water tank,there is
the hose is off tilt the handle back you will see it running down into the base
Posted on Dec 15, 2009
  • 34 Answers
SOURCE: I purchased a sunbeam ultrasonic
Trying to help...does # 2 or 4 look similar...any other numbers on the unit ?? http://homeappliance.manualsonline.com/search.html?m=&d=&q=sunbeam+sunbeam+warm+mist+humidifier&p=1
Posted on Nov 06, 2010
I am trying to find a replacement water tank cap for a Vicks V4450 humidifier. I dropped the cap and broke it on the edge. Everything I see on line does not say it will fit the V4450. My e-mail address is...
http://pg.custhelp.com/app/ask This is a link for Vicks online help section. I'd shoot them an email and simply ask if they can send or sell you a new one. Have the model number available.
http://www.pg.com/en_US/brands/health_wellbeing/index.shtml Here is the link for Proctor and Gamble who is the parent company of Vicks.
Good luck !
Mar 02, 2011 | Vacuums
My steam cleaner is leaking as soon as i put the clean water tank on machine
The most common reason for leakage is that the reservoir assembly has gone bad. If you look in the area behind the tank, you will see a rod that pushes down on a small round rubber seal when you squeeze the trigger. The assembly being pushed on is the reservoir, and the internal valve may be bad. This would require replacement of the assembly. ( Part # 43526016, msrp $6.49 ). Another possibility is that the seal that the tank sits on is worn or missing. There is a round black rubber seal that the tank sits on. There is a plastic pin in the middle which opens the tank outlet valve. I sometimes see this seal missing - usually because a child has pulled it off. If it is missing it must be replaced. ( Part # 38784060, msrp $1.29)
Feb 21, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I need a replacement cap for the water tank Sunbeam humidifier model swm5251
Official instruction from this device suggests to call Sunbeam consumer service at 1-888-264-9669 to order replacement accessories.
Nov 28, 2010 | Sunbeam Vacuums
Need a water tank safety cap for euro- pro canister steam cleaner model S3325H
I need a cap which is located on the back of the clean water tank on a Bissell model 1950-3 steam cleaner
Aug 20, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
Flow indicator does not spin when the trigger is depressed like nothing is coming through, pump?
Usually that is showing no soap in soap tank even if there is water in the water tank.After filling soap tank make sure it locks in real good ;Thats been my problem a few times.I didnt know the water and soap were in seperate tanks the first 2 times I used mine lol....
Jun 22, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
My floormate upper tank has a screw on filler cap nad the tank tank does not obviously come off the machine. The filer cap is under a hood and also cannot be used with iut removing the tank.I must not have...
Please let me know the model number from the data plate.
It is likely started with the letter "H", followed by at least for numbers.
It will allow me to post the User Manual to you.
Mar 12, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell Rug Cleaner Model 1695
I think you have the same problem as me, If you lay the handle down and remove the tank you'll see a vacuum hose that runs from about the middle of the machine back towards and up into the handle. that hose probably has a hole in it. which is my problem also I can't get at the part of the hose that runs into the handle. I hope I could at least help you figure out what the problem was.
Jan 19, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Solution will not exit fresh water tank
The early models of this machine had a pretty ugly defect in the clean water tank. They had all kinds of problems with them and now have a completely different tank to replace the old style. It sounds like you have a defective tank. When the tank sits on the machine, there is a center pin in the tank support that pushes on the tank valve(s) and released the solution into the machine. One of the problems was that the hot water would cause the plastic of the tank to become too plyable and the preassure of the center pin would bend the plastic up and then the valves would not open. You may have to replace your tank. Contact the Hoover company and tell them that you are aware of the many problems they had with this machine and they may make compromises on a replacement tank. Good Luck.
Jan 13, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
231 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
