Question about Elite Audio EA-6040 Theater System
None of the speakers are working only a bass sound is coming out but no words
I have a samsung LHB655NW surround sound system. The four corner speakers are double units with one above the other.the top ones work but no sound comes out of the lower ones.
If you are talking about the driver cones in each of the units, then it's odd that they should have gone, unless they have driven too hard or damaged (say by a child poking them). Double unit speakers have a crossover built into that separates the sound into treble and midrange or bass.
If the sound coming out is "treble" the high frequency that shows the bass units are not working.
Make certain all the wiring is good to the speakers and if you can see the bass speaker check it is not damaged.
If you need to, go inside the units and connect a 1.5 battery across each speaker terminal for a second. If it "pops" then it's working.
May 07, 2018 | Samsung Audio Players & Recorders
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
Buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
G..
Nov 03, 2011 | Logitech Z-4 Computer Speakers
Hi, I have lost the base in one of my bose 802 speakers, Tried all the obvious stuff, amp, eq, cables, etc with same results, can anybody help?
If you have switched speakers to confirm that that speaker is faulty and not your amp, it's a question of opening up the speaker and looking for obvious damage. If none then find the bass driver and remove one connection to it. Then with a 1.5 volt battery connect the + to the plus of the bass driver and the - to the other terminal. ONLY FOR A SPLIT SECONED! If the bass unit works it should pop and you should see the cone move. If it doesn't either the wire from the speaker has come away from the terminal point (bad soldering) or the coil is open circuit (new bass unit I'm afraid). If it does pop it's something on the crossover that's faulty. Check for bad soldering first.
Jun 25, 2010 | Audio Players & Recorders
The right speaker not working
Just opened mine just to realize that it only has on speaker on the side. Both sides dont have the bass speakers!
May 22, 2010 | Altec Lansing inMotion iM7 (021986950806)...
It comes on but no base sound and wont turn up
You have to fill in the details about what you're feeding it (the source and how IT's set up). It won't just >>create<< bass.
From the manual:
If you used the high-level (speaker) inputs and there
is no sound from any of the speakers:
• Check that receiver/amplifier is on and a source is playing.
• Check that powered subwoofer is plugged into an active electrical outlet and is switched on.
• Check all wires and connections between
receiver/amplifier and speakers. Make sure all wires
are connected. Make sure none of the speaker wires are
frayed, cut or punctured.
• Review proper operation of your receiver/amplifier.
If there is low (or no) bass output:
• Make sure the connections to the left and right “Speaker
Inputs” have the correct polarity (+ and –).
• Make sure that the subwoofer is plugged into an active electrical outlet and switched on.
• Adjust the crossover point.
• Flip the Phase Control switch to the opposite position.
• If you are using a Dolby Digital/DTS receiver or processor, make sure that the subwoofer adjustments on the receiver/processor are set up correctly.
• Slowly turn the Level Control clockwise until you begin to hear the desired amount of bass.
If you used the line-level inputs and there is no sound
from the subwoofer:
• Check all wires and connections between receiver/amplifier and subwoofer. Make sure all wires are connected. Make sure none
of the wires are frayed, cut or punctured.
• Make sure that you have configured your receiver/processor so that the subwoofer/LFE output is on.
Apr 07, 2010 | JBL PB12 Subwoofer
What niles power amplifer would work effortlessly with my bose 901 speakers? i am trying to achieve a deeper bass and tonal level treble for my speakers even at a low volume levle thanks.
The 901 Active Equalizer comes with some bass and midrange adjustment for tayloring them to your environment and taste.
Your question is about personal preference, which none of us could possibly answer.
Since any amplifier worth its salt should just make the sound BIGGER without coloring it, your question is moot. What you want is NOT a quality amp. Maybe an equalizer?
Mar 21, 2010 | Bose 901 VI Main / Stereo Speaker
Logitech Z-2300 subwoofer/Bass volume cannot completely shutoff
Make sure the wired remote is connected completely and if that doesn't work try putting a pillow or a pile of blankets to cover both the subwoofer driver and the air port on it and that should reduce the sound coming from it. Also if it is in a corner or on a solid floor like wood or tile i would move it to a less enclosed space with carpet or a rug. Thats all I got I hope that helps.
Feb 05, 2010 | Logitech Z-2300 Computer Speakers
Bass speaker issues
Are you saying that the woofer (big one) is connected to the same speakers in the same unit? Or is the Woofer on it's own?
If it is connected, then one of two things has happened. First the coil or connection to the speaker has broken or gone. The connection can easily be fixed with solder.
If it is the coil, then what you need to do is isolate the speaker from the rest. Then get a 1.5 volt battery and connect one end to one of the speaker connections and then the other end of the battery to the other, but for only a short time. If the speaker is working then the cone should move and it should pop. If it doesn't do either the speaker coil or speaker has failed and my guess is you will need to buy a replacement. If it does pop then it's good.
Your next step is to look at the crossover unit that connects all the speakers. Again check the connection wires and make certain they are good. You will see some large Inductors and capacitor(s) these control the bass section. You could replace the capacitor, it's likely to be a none polarised one. But check the inductor over too. It could have a bad connection.
Jan 27, 2018 | HP GM325AA#ABA 2 Speakers
Changing out my monitor speakers to bose cube speakers
You probably can do it as long as the speakers there now are 8 ohm speakers and you must use the bose bass module with the cubes because the crossover is built into the bass module for the cubes to work. If you just wire up the cubes you will mess the cubes up and they want sound right at all. The cubes are no good without their bass module in other words. Hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 09, 2008 | Bose Lifestyle 12 System
Elite Audio EA-6040 Theater System Logo
19 people viewed this question
Top Elite Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Elite Audio Player and Recorder Expert? Answer questions, earn points and help others
