Question about Solis Master 5000 Espresso Machine
When I brew, everything sounds fine until the water comes out. There's usually a good burst right at the start but then I hear clicks and the the water slows way down. Brownish water comes out UNDER the water catch tray and leaks all over the table. Help!!
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
Posted on May 19, 2009
Can hear the grinder and brewing unit run but only hot water comes out
Have you completely opened and cleaned the entire unit yet? I sounds like your coffee is not passing from the grinding area to the basket; so when the brew cycle starts, it is just running the hot water over an empty grounds basket.
Make sure that the unit is unplugged before cleaning it.
Apr 03, 2015 | Coffee Makers & Espresso Machines
My keurig 2.0 will not brew. Everything works fine up until you press the brew button. It sounds like it is going to brew for about a half a second and then it just stops. A fee drops of wwater come o
If it is an older one it has probably limed up and needs cleaned with white vinegar. Run through it repeatedly until things come out clean & not cloudy.
Dec 12, 2014 | Keurig K350 2.0 Brewer
My black and decker coffee pot wont brew everything seems to be fine all the lights and the clock work but when i push on it wont start brewing
There is a momentary contact switch that is probably. You gran get one at the mfr. or maybe locally. When you press the brew button, you should hearing it engage . That would be a sound and a click like something has connected. If there is no sound, then your momentary contact switch is bad. Not too expensive. Probably a 5-10 minute job.
Feb 02, 2013 | Applica Black And Decker 12 Cup...
Red light won't stop flashing. Parts are in place
Be sure all coffee grounds are cleaned from beneath the water tray and the grounds tray and the coffee brew group. We had the same problem but finally redid everything, including cleaning the coffee brew group under hot water, drying and replacing carefully until it clicked in place. The moving parts of brew group have to be in exactly the right place. Good luck!
May 12, 2012 | Saeco Spidem Villa
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
B70 keurig wont heat up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Nov 28, 2009 | Keurig B70 Coffee Maker
The water starts flowing for about a minute then stops for a minute then starts for a minute and continues that cycle until it fills the air pot and stops. I have cleaned all the filters in line, checked...
This sounds like normal operation of this type of unit.
Look at the brew funnel. is coffee coming out of it all the time during the brew cycle?
If so, then what you are hearing is the water supply solenoid cycling.
Oct 16, 2009 | Bunn GMB-PS Coffee Maker
I PUT SWITCH ON FULL BREW AND IT STOPS WITHIN 30 SECONDS. WHEN I PUT IT ON HALF BREW IT DOESN'T STOP RUNNING
It sounds to me like the Timer board is damaged, to test it set the small lock lever on the board to on (hopefully you have the electronic timer board in there) then select the cycle half or full then hold down the brew button until you hear 3 clicks then release. After about 1min or if using a measuring pitcher stop the brewer a 2ltrs, by turning the on/off switch off. Wait until flow stops then check water level and note. Turn brewer back on and press and release brew button and this time if it stops and gives you the same amount as you just got when programming then the timer is fine, just recalibrate it for full brew using the method above.
May 18, 2009 | Bunn U3 / SS 20500-0000 Coffee Maker
New to expresso machine - Cuisinart EM100c
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
May 10, 2009 | Cuisinart EM-200 Espresso Machine
Lift the lever, but nothing happen - no sound, no action...
This happened to me. If you look closely at the lever you will see that the action of lifting the lever presses in a switch that is right behind the lever on the front of the machine. This switch starts the brew pump. One of the wires connected to this switch has rattled loose and lost contact. To fix this you will have to take the top of the case (the lid) off and then use long needle nose pliers to try to grab the loose wire and re-attach it to the switch. There is not much room to manuver, but I managed to do it eventually. Unplug the machine first, of course!
Sep 05, 2007 | ECM Giotto Espresso Machine
Solis Master 5000 Espresso Machine Logo
41 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
