Question about Hotpoint RGB535 Gas Kitchen Range
Oven beeps and reads F2 - Hotpoint RGB535 Gas Kitchen Range
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
F2 (During Bake)
- Oven Control Senses Oven Temperature Above 615F-630F - If temperature has exceeded 615F-630F, check for welded contacts on bake and broil relays. If present, replace control board (clock). If temperature has NOT exceeded 615F-630F, check sensor, sensor harness, and the sensor harness connection at sensor and oven control. If found defective, replace sensor. Also check for any causes of high resistance in the oven temperature sensor circuit.
F2 (During Clean)
- Oven Control Senses Oven Temperature Above 915F-930F - If temperature has exceeded 915F-930F, check for welded contacts on the bake and broil relays. If present, replace control board (clock). If temperature has NOT exceeded 915F-930F, check sensor, sensor harness, and the sensor harness connection at sensor and oven control. If found defective, replace sensor. Also check for any causes of high resistance in the oven temperature sensor circuit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
Apr 21, 2014 | Whirlpool Ovens
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
Read more :
Jan 19, 2014 | Thermador Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
F2 beeping
F2 indicates that temperature inside the oven has gotten to high. The sensor should read around 1000 ohms at room temperature if not it is bad. Here is the part to order.
Mar 17, 2013 | GE Spectra JBP78 Electric Kitchen Range
F2 code on GE selfcleaning oven
The F2 fault code generally means the Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor Might want to check the oven sensor for high resistance. Get a ohm reading of the oven sensor at room temperature and tell me what this reading is.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | GE Ovens
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Ge gas oven/ranger xl44
The F2 is the code for the board seeing a temp higher than 600 degrees. It could be one of two things. The temp sensor is out of range, extreme high resistance. If you ohm it out it should read approx 1100 ohms at room temp. The other would be a welded bake relay on the board itself. Check the temp sensor first. If you are getting the F2 in the cleaning cycle, check the temp sensor, welded clean cycle contacts on the board or both contacts on the lock switch are closed at the same time. This is for the model posted JGBP90.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
Hotpoint RGB535 Gas Kitchen Range Logo
154 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
