Question about Mitsubishi WD-52525 52" Rear Projection HDTV
MITS DLP "HELP"
My Mits was recently down with no picture due to the bulb going out. I replaced the bulb but continued to get the lamp error. I had a repair person come out and found that the jack the bulb plugs into had fallen out of the bracket back inside the TV. It was a $120 fix. It worked well for about one month and now I see uneven light coming through and the brightness is all jacked up. It looks like the old school projection TV's. I am not sure if there is a reset or adjustment once you replace a bulb.
HELP!
Thanks,
Jimmy
  • MICHAEL MULLINS May 11, 2010
    Good Day, jimmy;
    There is no adjustment after replacing the lamp, but not sure what you mean about an uneven light coming through. Unless there is finger prints on the lamp or lamp window. If it's color blobs on the screen, the TV may have a failed light engine.
    Good Luck, Big Irish.
  • 927 Answers
Good Day, jimmy;
Did you get the TV repaired yet, or did forget about us??
Posted on Jul 19, 2008
Lamp Problems
If you put in an osram "neolux" type lamp--these will NOT often work in Mits. tv sets. And MIts often sends out Neolux bulbs now. A phillpis bulb for this works MUCH better.
May 02, 2014 | Mitsubishi WD-82738 model 82-Inch 3D DLP...
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
My TV will not turn on. I just replaced the tv lamp 2 weeks ago. Help!!
did you use original Mits Lamp or a generic?? most mits DLP tvs wont run long or at all with generic lamps
Sep 30, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
57" Mitsubishi won't power on, blinks green timer light
It is a common failure of the 57" Mits. DLP. The problem is a defective thermistor and is covered by Mits. Contact a local repair shop and they will fix it free (parts & labor)
Sep 04, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Dead lamp!!!
is it tha lamp cracked? are you using original lamp from mits? i founded people using aftermarket lamps with other specks this lamp is 150 watts ,this info its going to help.
if components on the Power board K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects are a deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010 let me know if you need anything else
Jul 04, 2008 | Mitsubishi WD-57732 Projection Television
Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Apr 20, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
