Question about Refrigerators
The icemaker on our LG french door, bottom freezer refrigerator is not working. It looks like the automatic shut-off arm has dropped to low and is getting stuck on the bin. We got the refrigerator in March 2010.
  • mcgateway Jan 01, 2011
    Thanks. Will do that on Monday.
    President:
  • 2,468 Answers
If its only that old contact the manufacturer directly as its still under full warranty
Posted on Jan 01, 2011
  • 6,993 Answers
Have you tried the solution yet? What's the outcome?
Bye for now.
Posted on Jan 03, 2011
How to get icemaker working on the refrigerator
Check to see if water is on going to it and look for a lever that drops down into the bin that turns it on. When the bin is ful of ice, it goes up and shuts it of.
Apr 02, 2014 | Samsung RF265AA Bottom Freezer French Door...
LG French door refrigerator bottom freezer not working
Check inside vents are clear and door seal is good. Check air compressor area is clean and well ventilated. Put setting in a low number and turn off / unplug unit, count to 10 and plug in, turn on.
Crossing fingers helps too ;)
Mar 30, 2014 | LG 7841 Bottom Freezer French Door...
Lg icemaker stuck
You have an overflow of ice building up in the reservoir. Turn off the maker and use the contents until 3/4 are used up. Turn on again and stop when near full. Check to see if the LEVEL of the refrigerator is correct. The BOX may be tilted forward and an adjustment made.
Feb 26, 2014 | Refrigerators
GE FRENCH DOOR REFRIGERATOR DOES NOT MAKE ICE
First thing to check is if the freezer temperature is going down low enough for the ice maker to work - around 10 degrees. The icemaker thermostat will not activate the mechanism (cam motor) unless this requirement is met.
Nov 27, 2013 | GE Profile PFSF6PK Bottom Freezer French...
The icemaker on my Maytag Refrigerator MFD2560HES bottom freezer with French Doors has not made any ice for about two weeks. Before this, it would go for a few days and not make ice and just when I was...
Mine (same model) does the same thing. The only way I get it to work is to open the freezer, and move the metal ice lever arm up and back down again. Then it starts. But after a day, the arm stops moving and it breaks. I can't stand it anymore.
Before moving into my new house with the mfd2560hes, I had to replace an ice maker in my whirlpool refrigerator. So, I guess I'll be googling this maytag model and buying an icemaker motor replacement kit.
if I'm successfull, I'll post it here.
May 03, 2010 | Maytag MFD2560HES Bottom Freezer French...
Icemaker stops. lever to shut off icemaker frozen in place. used hair dryer to melt frozen gears and loosen lever, but water gets into gear housing again and freezes lever again
These icemakers are not repairiable.
The icemaker will need to be replaced with LG part#
AEQ36756901
This is an updated icemaker to correct the problems of past units.
Jan 17, 2010 | LG LFX25960 Bottom Freezer French Door...
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
Ice tastes like plastic. New LG French Door.
Change the filter each week until problem is gone. LG is not usually hit with this problem. good luck.
Jun 09, 2009 | LG LFC25760 French Door Refrigerator
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
