Question about HP Photosmart C3150 Printer
Scanner I dont know how to scan a document, would you please....
Just put in something to scan and hit the bottom button
it should handle the scanning on its own
then look for the picture on your computer
Posted on Jul 22, 2008
Dont know how to scan a document
The first thing that you must do is make sure that the device is already installed to your computer. Insert the document to be scanned on the scanner. Double click the icon of your scanner and on the option menu click scan. After the scanning process, open the My Picture folder of your computer and locate the image file.
Sep 02, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
I want to scan documents but i don't know how to do it. please give me the steps to operate the scanner
Title: Scanning a document
Hi, at first connect your scanner with your pc then-
?? Install your driver
?? After installation restart your computer.
?? When your computer start, go to "Start " and see the new installed software, open it and choose "Ulead photo Express" any thing which is your scanner supported.
?? Then open your scanner and put document into the scanner.
?? Close the cover.
?? In scanner a scan button is there , just push it.
?? Scanning will be start automatically.
Thanks!
May 13, 2011 | Computers & Internet
HI, The easiest procedure to scan a document using your scanner is open Paintbrush that is installed with your operating system. Click on File Menu at the top left corner of your screen, then select "From Scanner or Camera". Once you have selected the option, you will be prompted for your scanner. Select the installed scanner and go on scanning the image/document placed on the glass bed of your scanner. Once the scanning has been completed, save the image file.
Cheers!
Mar 06, 2010 | HP Photosmart C5180 All-In-One InkJet...
How do i use the scanner to print a document?
My friend, you have the cart before the horse. Let me explain.
The technology used to scan is TWAIN which means Technology Without A Interesting Name.
If you want your scanner to print your document, first you have to scan it into your computer, using your TWAIN software. You will want to import the scan from the scanner as a word document not a picture (of words).
Following that process, you will have to load the new document into a word processor of some kind and send the document to the printer.
Most 'all in one' devices also copy. Why dont you copy the document instead of scan it? I dont know ... but this is the process.
Reminder, if you just scan the documednt, you may end up with a picture full of words that you will not be able to edit. You must import it as a document if you expect to edit.
Thanks for posting your question to FixYa.com
lease vote
thanks
a
Dec 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Will not Scan. Gets message..
Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
Nov 07, 2009 | HP Photosmart 3210 Printer
Scanning with Windows XP
first make sure the printer is installed to the os, if the cd wont work download the driver from the manufacturer website. then connect the device to the computer so that the scan can actually go some place. i believe this particular model has a scan buitton on the device however i am not so sure so please double check. if it does press the button. if not u have to scan the document with the software installed
Jul 08, 2009 | Canon PIXMA MX300 All-in-One Printer
Black line on scanned document
Please clean the glass with Isopropyl alcohol. Dont use solvents.
S. Mohan
Mar 27, 2009 | Canon DR-1210C Scanner
How to use the scanner on my Epson 60000
there are different type of scannig programs. I am not that particular with your epson scanner. You can try scanning the document and if you want to archive it you can try choosig the option of file type as compressed tif. If you do not have this option there would be times that scanning software will have the preview of the document you have scanned and will asked you if you want to reduce or enlarge size. If resizing option is not available in your scanner software you can try saving it first in your computer. After saving the document try to open microsoft word and create a new file. Then look for the document you have scanned and copy that document. Once you have copied it go back to microsoft word and paste the documet. you could now resize the document manually. but for further clarification you can try calling your scanner provider. they might have some programs for it and will give it to you
Nov 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Smartbase MP360 Scanner Not Identified by MS Vista
One thing to check and be sure of is that your printer cable (USB) is definately a USB 2.0 cable. Canon have an issue with their printers with scanners in that the data flow sometimes isn't sufficient when an older USB cable is used. The slightest drop of data on startup or during scanning will cause a stop.
Worth trying and has sometimes solved the problem for my customers.
Aug 23, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Multi scanning
scanners only scan one side printing on the other hand is where you want back to front documents
flatbed scanners dont do multi there individule scans if you want multi conversions by the all in one scanner printer fax this scans both sides prints both sides together
May 10, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
HP Photosmart C3150 Printer Logo
170 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
