Question about HP LaserJet 1100 Printer
HP laserjet 1100 won't print from Vista laptop
I purchased a new Vista Gateway laptop , bought a DB25 connector cable to connect the HP's existing cable and plugged it into the USB port. At first the pc found and installed the printer, but when i printed my ivoice from quickbooks they came out garbled. Eventually the printed correctly. A while later I printed another one, garbled again.
The next day I rebooted both pc and printer, no the device is offline and I can't print at tall. Any ideas!!
Am I going to need to buy a newer laserjet?
  • tsbower Aug 23, 2008
    I had exactly the same thing happen when printed in MS Word with Windows Vista, a laptop with the correct printer cable attached to USB of laptop.
  • 59 Answers
Hello jdh,
You can download the driver for vista through this Link
Just choose which device you have then choose Drivers For Vista.
Thanks for using FixYa.
Posted on Apr 10, 2009
  • 32 Answers
Which version of QuickBooks are you using? Anything older than 2008 will not work with vista.
Posted on Feb 18, 2009
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
How to connect to the computer?
Devices: Canon CanoScan FB330P/FB630P Color Flatbed Scanners
Check pages 22-23 of this copy of your Canon Canoscan 630P Product Guide.
You'll need an "IBM-type" parallel printer cable - with a DB25 on each end, and your computer will also need to have an "IBM-type" DB-25 parallel printer port.
What the Canon Product Guide fails to mention is that this "IBM-type" printer cable is a kluged Centronics parallel printer cable, but became so popular (on older computers - your laptop may not have this port), that it got an IEEE standard: IEEE 1284 (with DB25 connectors on both ends).
You'll need a DB25-to-DB25 M/F cable, meaning DB25 connectors on both ends, with a Male on one end, and a Female on the other end.
The Male DB25 will plug into the Female DB25 connector on your computer/laptop, with the Female DB25 going to the FB630P Color scanner..
Here are some pictures/pricing:
The nice thing about the design of the Canon FB630P Color Scanner is that the scanner also has a Female DB25 Printer port for an existing parallel printer, so when you connect an FB330P/FB630P to your system, your existing parallel printer is daisy-chained through this port - so you needn't give up you printer (to scan), nor must you install another parallel printer port onto your PCI-bus tower PC to keep your printer.
Canon Canoscan FB330P/FB630P Color Scanner Product Guide (82 pages):
Most modern printers are USB-attached to laptop systems, so you may need an adapter, an example of which is seen here:
Dec 05, 2011 | Canon CanoScan FB630P Flatbed Scanner
Vista will not print to HP Laserjet 5p
I purchased a Dynex USB to Parallel Converter Cable from Best Buy and tried to connect but had no success. I then sent an email to Dynex customer service and received a reply in about 24 hours. The rep provided spot on instructions which I was able to follow to a tee. My 14 year old HP Laserjet 5P is now ready to run until it blows up.
I spent hours searching web forums and only received overcomplicated replies by people who think they are techies, none of which worked. I am 63 years old and not a techie, so if I can do it, anyone can. I have saved the email and will forward this straightforward simple fix to anyone who needs it. My net cost was $36.00 for the cable.
Sep 05, 2009 | HP LaserJet 5p Printer
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
Jun 24, 2009 | HP LaserJet P2015 Printer
Toshiba satellite E100» laptop and HP laserjet 3030 printer
Check the HP website and see if there are Vista drivers for your model. If you installed them from the disk they're likely not compatible.
Apr 27, 2009 | Toshiba Computers & Internet
HP laserjet 1320n keeps printing jetdirect configuration page
Are the proper drivers installed on each system?...Vista will not work properly on XP and vice versa. Make sure they are insttalled correctly
Mar 03, 2009 | HP LaserJet 1320 Printer
Vista problems with NEC SuperScript 870
If you load the printer drivers from a Windows XP install disk (in the i386 directory), that worked for me.
Feb 22, 2008 | NEC SuperScript 870 Laser Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from
Jan 20, 2008 | HP LaserJet 6L Printer
HP LaserJet 1100 Printer Logo
237 people viewed this question
Ben Johnson
