Question about Fellowes CD Lens Cleaner (99761) CD-R CD / DVD Cleaning Disk
How do I use the cleaning disk and fluid - Fellowes CD Lens Cleaner (99761) CD-R CD / DVD Cleaning Disk
    Genius:
  • 1,288 Answers
As I recall, insert the disc into the drive and let it spin up ( I'm assuming this is the cleaning disk with a set of soft small bristles on the surface), there is normally a small video that tells you when the drive laser lens has been cleaned. I'm not too sure about the cleaning fluid
Posted on Jan 01, 2011
Cd keeps skeeping
You can try to clean it with a soft cloth. I would check the disk for scratches. If that doesn't work, you can try it in a different player. If it works in a different player, the other player needs cleaned or replaced. It is possible the disk is damaged beyond repair.
Apr 21, 2015 | Audio Players & Recorders
Replace front brake discs
Remove wheels.
Remove calipers and caliper mounting brackets.
Remove brake disk.
Replace new disk, being sure to clean it thoroughly with brake cleaner and a clean rag.
Replace caliper mounting bracket.
Replace new brake pads.
Push back caliper piston.
Re-attach brake caliper.
Repeat on other side.
Remove brake fluid reservoir cap.
Pump brake pedal until hard.
**** out any excess fluid from master cylinder reservoir.
Replace cap.
Wash off any excess fluid with water and dry thoroughly.
Road-test
Be sure to keep to a slower speed than usual and keep extended braking distances until new pads and disks are bedded in.
Nov 07, 2012 | 1999 Daewoo Matiz
Will not read CD's
get a dvd cleaning disk that comes with cleaning fluid ( it it doesn't have fluid with it don't buy it) or bring it in for repair to have the lens cleaned. if cleaning doesn't fix it then the lazer is bad or motor.
Jun 17, 2011 | Sony MXD-D40 Mini Disc Player
My dvd recoreder keeps saying cannot read disk. keeps ejecting disk when ever i insert a disk
get a laser lens cleaning disk .($2 to $10) . it looks like a standard CD but has fine little burshes that remove dust from the laser ...that may not work if anyone smokes around the machne .. in that case the cover has to be removed and the laser manually cleaned (with eye glass cleaning fluid on a soft paper towell) ..if that doesnt work then the laser may be just worn out ... replacement is usually more than the cost of a new unit ... make sure your disks are clean .. you can wash the shiney side with mild soap and water ... rince and pat dry .. dont use hot water ...
Apr 11, 2010 | Samsung DVD-R155
How do I use the DVD cleaning disc, fluid and disc-shaped cloth? No instructions are included or else we lost them
put cleanung disk in drive put some fluid on the disk and let disk spins after you do thad leave disk a wile open for drying the lens
Mar 23, 2010 | Fellowes CD Lens Cleaner (99761) CD-R CD /...
I can't get a Sony 3" disk to work. The screen says "No Disk" that's it then it rumbles, clicks nad spins...What's up?
you probably need to clean the drive heads .. you can do that with a "cleaning disk" .. that looks like a normal 3" disk but has a fiber like disk .. on some you add a couple of drops of cleaning fluid ..on others you just run it dry ..
here is an example of a cleaning kit .. ...
http://www.amazon.com/Kensington-Disk-Drive-Cleaning-3-5in/dp/B000067S3R
you might find it for less .. prehaps at radio shack .. or one of the electronic stores ..
here is one on ebay ...........
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260519540850&rvr_id=&crlp=1_263602_263622&UA=L*F%3F&GUID=495319691260a0aad253b343fd90435d&itemid=260519540850&ff4=263602_263622
sometimes you have to take the drive out and manually clean the heads but thats a big and messy job .. once in a while the drive has some other defect but usually its just dirty heads ..
Jan 20, 2010 | Sony Mavica MVC-CD400 Digital Camera
Xbox 360 reads game disks as DVDS , And I get the screen that says Put this 360 game in to a Xbox, the game is in a xbox!
check around the disk tray for dust and use a vaccum cleaner to clean it, then use a wet cd lens cleaner with cleaning fluid a few time.
This should cure the problem but it might be that your drive is dead
Nov 07, 2009 | Microsoft Xbox 360 Console
My laptop will not read disks. I am trying to play a game and the error message comes up "please insert a disk"
well two things here
1) The drive needs cleaning, use a CD Drive cleaner It is a CD with a little brush grafted into the CD. Run this to clean the scanner eye
2) the disk is faulty, check for finger marks on surface.
Essentials for disks
Scanner cleaner
Disk cleaner fluid
Scratch repair kit
Aug 13, 2009 | HP Pavilion dv6000z Notebook
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Irritated
OK YOUR DVD DRIVE HAS A LENS PROBLEM
BRING A DVD CLEANER DISK AND ADD LENS CLEANING FLUID TO THE CD S READING SURFACE AND INSERT THE DISK TO THE DRIVE AND WAIT FOR 1 MINUTE THEN EJECT AND REPEAT THE PROCEDURE WITHOUT LENS CLEANING FLUID
AND OF COURSE THE CD SHOULD BE DRIED OFF BEFORE YU INSERT IT TO THE DVD ROM
Dec 03, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Fellowes CD Lens Cleaner (99761) CD-R CD / DVD Cleaning Disk Logo
176 people viewed this question
Top Fellowes Electronics - Others Experts
Are you a Fellowes Electronics - Other Expert? Answer questions, earn points and help others
