Question about Dryers
This dryer is running on propane. Its been running well for the last two years. It just stopped Igniting. What typically goes wrong with this model? Is it the thermostat or the Igniter? Or what is not working?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Here is a video to walk you thru the diagnostics to find the failed component.
Posted on Jan 01, 2011
  • 1,772 Answers
Hello and sorry to hear about your problem.
It sounds like your oven glow rod, is defective. This is the electronic pilot lite for the unit.
or their is a chance, that the gas control valve is defective.
I have tried to help you. Please help me by Vote/Rate this response. Thanks and good luck.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Propane gas kitchen aid dryer is not heating. Model number KGYE660WWH1, dryer is over 14 years old, any suggestions to fix it? Spoke to gas company and there is no problem there...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Dryers
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
My Maytag Alliance gas dryer won't heat up at all. The dryer keeps running due to the temperature not changing. There is no heat at all. I ran out of propane - the dryer stopped during the cycle, the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 05, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
I bought at Dometic propane/ electric fridge for my cabin last year. It has not run properly since. The fridge will light and run for a while with a blue flame but sometimes in the idle mode it goes out....
I have to ask, what is idle mode? I've never seen one that runs on idle mode, in a RV in 15 years. Has anyone used a manometer and tested Inches of water column in propane supply to fridge, as well as other appliances?
Any I've seen run on propane, are either on, (flame present, or off, no flame present.) Flame goes out completely when not calling for cool.
Jun 13, 2010 | Dometic RM2620 Refrigerator
When i start my oven in mt propane stove goes puff
disassemble and **** orifices and clean , spiders etc plug up all the time , propane is nothing you want poofing when igniting!
Aug 23, 2009 | Tappan MGF500PBW Gas Kitchen Range
Whirlpool gas (Propane) dryer
Hi, Remove the small plastic cover on the front lower right hand corner. Start the dryer and see id=f the ignitor glows. If the ignitor glows and shuts down before igniting the flame, follow these instructions. UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 19, 2009 | Whirlpool LER4634J Electric Dryer
Does not dry completely
how well did you clean that duct, the duct is problem 90% of the time when the dryer does everything else, pretty much if the dryer heats and tumbles its doing its job
May 04, 2009 | Dryers
No Heat
have same problem with my dryer. Check your sensor out,
Jun 14, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
