Question about RCA 25250RE1 2-Line Cordless Phone
I can record an OGA, but when people call they get the automated default message. How can I set the OGA so that it replaces the default message?
    President:
  • 2,992 Answers
Once you record your own message, it replaces the default one. If callers are still getting a different announcement, it's likely they aren't ever reaching your machine. Make sure that your telephone line voicemail service isn't picking up the calls instead. I've known several people with this same trouble, and they needed to modify their home voicemail (or whatever your service provider calls theirs) settings or turn it off. Then their phone answering machines worked properly.
Posted on Jan 01, 2011
How to set up voice mail
Here are all the steps you will need. Good luck:
  1. From the Home screen, tap Phone .
  2. Tap Voicemail .
    You could be directed to the automated Voice Mail system at this time. If so, follow the voice prompts to set up your Voice Mail and greeting instead of completing the steps below.
  3. Tap Set Up Now.
  4. Enter a password then tap Done.
    The password must be between 4-6 digits in length.
  5. Re-enter the password then tap Done.
  6. Tap Custom to record a greeting.
    To use a Verizon default greeting, tap (check) Default.
  7. Tap Record to begin.
  8. When finished, tap Stop.
  9. Tap Save.
Apr 25, 2016 | Cell Phones
How do I set up voice mail
How to record a voicemail
    1)Call your Voicemail access number, or press its corresponding shortcut key (usually the number "1").
    2)Press the key corresponding to "set your voicemail greeting" or "Set up your voicemail."
    3)Decide whether you want to use an automated greeting, which usually gives out your number and advises callers that you're not available.
    4)Follow the prompts to record and save your greeting.
How to Record Voicemail Message on LG Phones
Nov 20, 2015 | LG Cell Phones
Setting up answering machine for UnidenDECT 6.0
To replace the default greeting with a personal one
( Uniden model D1680 & similar ):
1. press [MENU]
2. scroll to "Ans. Setup" then press [select]
3. scroll to "Record Greeting" then press [select]
4. It will display & tell you aloud to press [select]
5. Speak Clearly your desired greeting, then press [select]
6. press [END] to conclude & exit
Apr 18, 2015 | Uniden DECT 6.0 Cordless Phone
How do I record an outgoing message for my RCA 25250 Answering System?
Call your number from that phone you should record that way from the prompts
Jan 22, 2015 | RCA Lands Phones
I need to change the outgoing message on the main line. I can change the personal greeting, but I cannot find instructions regarding changing the main line's outgoing message
For Partner Voice Messaging....
Dial into voicemail. WHen prompted for the mailbox number
Enter 0 #
Pswd the default is 1234 followed by #
Option 3 is the record Automated Attendant menu prompt
the rest is self explanatory.
Nov 19, 2009 | Avaya Lucent Partner 616 Phone
Need setup help for ep5962
first set day and time... menu, mailboxes, set day/time, scroll to day, set, select, ok... then scroll to current time, set, dial pad four digits, 2 for am or 7 for pm, select save. now power on line 1 or 2 or both. phone is preprogrammed with 'hello, please leave a message after the tone.' to record your own use menu, mailboxes, select setup 1 or 2, then review/chng oga, then record new oga, then ok. record when screen changes, choose stop when you're done. shortcut: press and hold record, press and release mailbox line x, release when finished. you only record one line at a time, so you can have different messages on each line. even if it's the same, you must record each line. since you can only record one message the shortcut would be useful for an 'out to lunch, be back about 1-30' sort of message. then re-record a standard message when you get back from lunch. 'course, you really don't need an 'out to lunch' message, since people are accustomed to answering machines at any time of day. all the caller needs to know is that 'i can't get to the phone right now.' and they appreciate it when you keep it short.
Mar 05, 2009 | AT&T EP5962 5.8 GHz Corded / Cordless...
RCA 25205 wont answer correctly
Yeah, I've wasted all morning messing with this. My personal outgoing message keeps reverting back to default. I just got off the phone with RCA and here's the fix for that part of the problem. Go into "Configure Out-Going Announcement" (page 23) and then select "personal," This finally made it stay there. The number I called for help is 1-800-511-3180, or 1-866-285-4651. Good luck!
Oct 27, 2008 | RCA 25205RE1 Phone
RCA 25205 Visys will not record message
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
Aug 07, 2008 | RCA 25205RE1 Phone
My new RCA Model 25205RE1-1 1815MO does not want to record a OGA. It appears to be recording as it so states and counts the seconds as you are speaking. I press EXIT and the OGA is not played...
The RCA Manual in incorrect. Step 8 reads "Press Set/Save to start recording. Speak within 6 inches away from the Mic located under SPEAKER button." Step 9 reads "Press EXIT to stop recording." Step 10 reads "The OGA is played automatically for your verification. It will then return to the OGA REC menu to start over or to record another OGA."
Step 9 should read "Press Set/Save to stop recording and the OGA is played automatically for your verification."
Step 10 should read "Press EXIT if recording is acceptable. Press Set/Save if you want to re-record."
By following the Manual you never save your message. "Playback" always has the Default message that comes on the machine. Furthermore, Customer Service at 310-953-9028 doesn't have a clue.
Jul 01, 2008 | RCA Lands Phones
Change message
oga recording shortcut... press and hold record... press and release line 1 or 2... release record when finished. or use the menu screens to get to record and playback oga.
Feb 21, 2008 | AT&T EP5962 5.8 GHz Corded / Cordless...
RCA 25250RE1 2-Line Cordless Phone Logo
323 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
