Question about HP PSC 1350v All-In-One InkJet Printer
Paper won't feed properly I have behaved rudely with it in a hurry and unable to get paper out (I think) without yanking it out
    Sergeant:
    Novelist:
  • 179 Answers
It sounds like you've left a piece/pieces of paper stuck inside the mechanism. If you can't see them to get them out (nicely ;-) then you may have to have the machine dismantled to repair it.
Hope that's helpful.
Posted on Jan 01, 2011
Media jam not take paper sheet
This is so very common with these machines. Unfortunately, you can damage the roller just underneath the paper feed if you aren\'t careful. Konica know that this problem persists, but will do nothing about it.
Their Customer Service - as well as management - gets very rude and quite offensive when questioning them on the subject.
I virtually have strip the thing down, just to clear bits of torn paper - too often.
I won\'t buy K.Minolta stuff again.
Good Luck
Dec 26, 2012 | Konica Minolta Magicolor 2530 DL Laser...
Hi, we run a canon ir 2016i in our office, and frequently the paper feed doesn't work properly. Especially the paper out of tray 3 and 4 gets stuck almost all the time. But quite often the paper f
The only thing I can think of, without actually seeing it work, is the feed rollers. I've never liked the feed system on this model, seems to be very temperamental. It could also be the feed clutches. There was a modification that should have done years ago dealing with the feed system. I don't know if this applied to the extra two cassettes but the two upper paper pick-up assemblies were to be replaced. Gears were updated.
May 08, 2017 | Canon iR 2016i Black and White Copier
The printer won't feed the paper in properly. It turns crooked and then doesn't load in. Printer thinks there is either no paper or a jam. Can see anything physically in the way blocking the...
Hi Trevo
First, check the the paper guide in the feed tray is up against the edge of the paper. If it is not snug then the paper will skew.
If it is OK then check with a torch both sides of the paper path - where it goes in and where it comes out.
I've found bits in the path before now that are not seen at first.
This printer may have a removeable panel at the back where you can check a bit more easily.
May 25, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Epson Stylus C62, Yanked overfed amount of paper from printer. Printer was jammed. Paper would not feed. After yanking out paper the carridge will not return, paper wont feed, printer shuts doown after a...
Probably not - a belt was either yanked out of its cog or a roller was popped out of its bearings. Since you have nothing left to lose just dismantle the printer (only a screwdriver is needed) and try to put the parts back together. If you fail, just get a new one.
Aug 27, 2010 | Epson Stylus C62 InkJet Printer
No paper jam, but keeps stating printer error-check paper.
This is an indication of the machine being unable to feed the paper. Since this is a rear feed machine sometimes things can fall into the paper feed slot so I would remove the paper and look into the port where the paper goes. Also while your there look for a small rubber tire that feeds the paper in. If you can get to it try cleaning it with a cloth and some glass cleaner. They will get paper dust built up on them and not feed properly.
Good Luck
Oct 20, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
I do not know how to feed the paper into this. I
It feeds into the slot just below the back top edge (see the manual. Be sure thatyou have the proper size papre--2 1/4 inch.
CLICK HERE:
http://downloads.canon.com/cpr/software/calculator/P23-DHV-(USA-HWB).pdf
ps. let the manual load all the way, it's pretty big.
Good luck
Oct 06, 2009 | Canon P23-DHV Calculator
Keeps giving an out of paper warning when it is not out of paper.
I think you may need to have your paper feed sensor replaced.  It's hard to troubleshoot such a problem without being there are having spare parts to use.  I would suggest trying with thicker paper and possibly even damn ( not wet, just humid ) paper and see if the problem persists... if not, the sensors may just need replacing.
Jul 07, 2009 | Lexmark C522n Laser Printer
Hi my printer doesn't pull paper from tray1 even if it set to pull paper automatically from tray 1 and 2 inadditon to this it needs manuallly feed papers.
My HP OfficeJet 7310 behaved correctly on the automatice paper feed for a long time and then began to be unable to pick up the page or would grab 2 or 3 pages at once. I was about to spend the $$$ to replace it, maybe $400 at that time. Instead I watched it work again and angin or not work. Noice the 1 inch square piece of cork? I went to Hobby Lobby and for less than $2 bought a roll of very thin cork. I cut an inch square and replaced the one on the machine and it has worked perfectly since. I still have 99% of the cork roll. What it?
Jan 22, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
Epson Cx3200 paper jam
Then there is something stuck in the paper feed path which is holding up the sensor flag making it think there is paper in it.
Or maybe the sensor flag has been broken off by yanking paper out the wrong way when it gets stuck.
Get your vacuum cleaner and stick the hose down the paper feed path and see if it suck out a push pin, piece of paper paper, fur ball, eraser, coin, toe nail, false eye lash etc (all of which I have removed from machines with "paper jams")
Dec 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
HP PSC 1350v All-In-One InkJet Printer Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
