Question about GE JVM1650 1000 Watts Microwave Oven
My microwave keeps turning off on its own everytime i turn it on i have to reset the clock then as soon as im finished i go to use it then 2 seconds later it turns off ! what could be wrong
  • 1,772 Answers
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if your unit has power, and things lite. it is more likely you have a control/switch problem,
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Jan 01, 2011
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
Beneath the time on the clock. The word "mute"
I have 2 possible solutions for you.
1) press and hold the 0 button for 3 seconds. This may only turn the clock display on or off, but may also mute or unmute the beeps.
2) unplug the unit for 30 seconds to a minute. Plug it back in and it should be reset.
Mar 08, 2011 | Hotpoint RVM1635 Microwave Oven
GE Spacemaker Microwave powers off after few seconds of working
Hello :
This could happen because of a bad keypad . Just replace it and problem will be solved . I need you to think before replacing it . Because sometimes a new unit is better than repairing . Think it before !
good luck .
please rate !
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Shuts off after maximum of 8 seconds. does heat when on.
Sounds like the controller board has failed, assuming a circuit breaker has not tripped or fuse has not blown.
If all you do is reset the clock, and then it looses time, regardless of using the microwave, then it points to the clock/controller board.
If this only happens when you use the microwave portion for a few seconds, I would be suspicious of the microwave circuit, where there are several components that could cause the failure.
Jan 22, 2009 | Kenmore 80593 Microwave Oven
GE JVM1650CH01 Microwave Template
You can download GE owner's manuals and installation instructions here.
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
MW stops after 23 seconds.
PLESE CHECK RELAYS ON PCBOARD .ALSO TRY DISCONNECTING ALL CONNECTIONS TO FRONT PANEL LEAVE IT DISCONNECTED 5MIN THEN RECONNECT AND TRY THE ELECTRONICS SHOULD RESET .HOPE I HELPED BIT OF A WEIRD FAULT
May 09, 2007 | Panasonic NN-S553 1350 Watts Microwave...
GE JVM1650 1000 Watts Microwave Oven Logo
197 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
