Question about Garden
Where do I find a operators manuel for Stihl 028 WB?
  • 26 Answers
  • 582 Answers
GO ONLINE TO STIHL AND THEY HAVE A PDF SECTION YOU CAN DOWN LOAD OR PRINT
Posted on Jan 01, 2011
Stihl 028WB Starts on first pull then stalls and will not restart
Its getting fuel because of the start every time you will thinking, also the fuel hoses are properly? tank airation ok ? you looked the hose but it will mostly are rigidly in the corners where the connections are if you there to draw firm because the fuel goes otherwise back in the tank if if it there air can be come in you will not see that the hoses only looking is not enough they are porous in high priority I should replace in all any cases the hoses after this kind of age and also buy a service-kit for the carburetor will also sit irrevocably dirt in it and especially in view of the pulsing membrane where the float needle is operated by the material can be hard and dry. and can be rip.
Beware on the model and machine number in priority if you order in your Country parts for your carburetor because there are used 2 brands of carburetors Tillotson or the famous Walbro WT-16b by the Stihl model 028 ATTENTION i can see only the parts and numbers of model 028 attention by this the images are not off the 028 WB the WB behind it its not in my list therefore i can not give you the correct information they are maybe not selled in our Country or is not anymore in service. the partnumbers may also be different in your Country look if it was running the same way and if it has not succeed , remove the sparkplug but connected it again with the cable and ground it to push the plug on a metal place and pull the trigger look at the colour of the spark if you see a little spark it must be having a very light blue spark sometimes you can hear the spark if thats the power is very good . if its spark is red colored replace the ignition coil but only if you have seen it by a using a new correct type of sparkplug in priority.Try first to replace the sparkplug and if that will not help then there could be a problem like a thermical problem with the ignition coil. control also the on -off button and cableisolation is not damaged and all parts are good functional.
Dec 29, 2015 | Garden
Why no power To mY 028 wb chainsaw?
Time to rebuild the carb it sounds like. You didn't give me much to go on, so please give me a few more details.
Oct 12, 2014 | Stihl Garden
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
028 wb how do you gap the points with the flywheel removed
You need a cam tool--probably easier to see your Stihl dealer and have them set the points. Good luck!
May 04, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Stihl chainsaw 028 wb will not start it has spark, but always floods, I cleaned the air cleaner
Does the saw have a lot of hours on it ? What is the fuel mix you are using, Stihl recommend 40:1
You may need a CARB KIT.
Feb 02, 2010 | Garden
I need a fuel hose diagram for a stihl model 028 wb chain saw.
Stihl IPLs (exploded parts list) are propriatary, You can request one here: The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
http://www.stihlusa.com/contact.php
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/images/Lou98321/fuelsystem.jpg
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Dec 23, 2009 | Garden
Removing flywheel and clutch assembly ms 250 stihl
You need a piston stop, watch part of this to explain use:
http://www.youtube.com/watch?v=cdqkIuVNUQc
Make one with starter cord or rope:
I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises. HTH
Lou
Nov 18, 2009 | Garden
NEED NEW CHAIN DRIVE UNIT INCLUDING PLASTIC
The model 028 Stihl Chainsaw was in production for many years and the clutch drum sprocket (or chain drive) came in three (3) versions over the years of production.
For several reasons, it is best to take the saw to an authorized Stihl Dealership (Locate your nearest dealership HERE) for production identification, evaluation of cost-effectivness and availability of parts.
Reason 1) The first-generation 028 saw is approaching 30 years old.
Reason 2) Extreme heat caused by a locked chain-brake can damage the engine case and render the saw unfixable (part support is going away due to age).
Reason 3) The shear cost of parts and amount of time it would take for a DIY repair.
Reason 4) The plastic gears you mentioned are the drive system that make the chain's oil pump work. If the plastic is melted, the oil pump is likely to be damaged as well. In most cases the oil pump cover gets damaged ... the list goes on and on.
Genuine Stihl parts are not sold online and aftermarket parts would be a gamble. It's up to you to decide if the cost, time and effort are worth it.
Hope this helps.
Oct 04, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
263 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
