Question about U-Line BI-95
Hi, I just replaced the water flow valve, and I need to adjust the flow level because the ice is one thick piece instead of many pieces. How do I adjust the flow level?
  • jsducki Jan 03, 2011
    Thank you so much, I am still making small adjustments.
  • 2,605 Answers
Welcome to FixYa,
If you remove the small white square cover from the icemaker head, ( just pulls off ) you should see a small screw as shown here...
I'm not certain of the direction to turn for more or less water (larger or smaller cubes) but you can experiment with it...just make small adjustments of 1/4 turn at a time though.
Let me know how you make out or if you need further assistance and I'll help in any manner I can.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Jan 01, 2011
Maytag H2O MFI2568AES Ice Maker keeps jamming
Most ice and water units have heater elements inside the door and in the ice chute itself to prevent water and ice from freezing in those areas. Its possible that one of the heater elements has failed. You will need a wiring diagram and a meter to test if the element is OK or not.
Feb 22, 2014 | Refrigerators
Water reasavore over flowes
Replacing Manitowoc water level probe and Ice Thickness
Feb 12, 2013 | Manitowoc SY0454A S Series Ice Maker...
Ice maker not making ice
The probelm is your not getting enough water to fill the ice maker up. This could be caused by a variety of things. I'll go over the most common ones.
1) Check the water filter. If the filter is out of date or has a severe enough calcium build-up it will restrict water flow
2) Is there a blockage in the fill tube of the icemaker?
3) is there calcium build uip at the valve? Turn the water off and remove the water line from the valve and inspect.
4)The valve may be going bad not allowing the solenoid to open completly causing less water.
With all that said there is a place on the icemaker itself that the water level can be adjusted, but be cautious. Too nuch if a turn and you may end uo flooding your kitchen.
May 20, 2012 | Frigidaire Refrigerators
Ice maker hose running, not shutting off when ice tray is full causeing it to over flow. What can be done? Model CSX24D side by side
Replace the water valve ( pt # WR57X10051 ) . This piece is what the wall water line connects to on the refrig . Also , due to the age of the refrig , I would suggest removing the ice maker ( 2 screws ) and inspecting the inside of the mold for coating disintegration which would cause water to seep thru the uncoated aluminum ( or bubbled coating ) causing the ice maker to leak , but , appear to be overfilling . In this case , replace the ice maker instead .
Aug 05, 2010 | Hotpoint Refrigerators
Valve to stop water from running
IF YOU HAVE A FLUIDMASTER BALLCOCK,AND IF THE WATER IS CONTINUING TO RUN ,YOU NEED TO ADJUST THE WATER LEVEL,MOST OS THE TIME ALL YOU HAVE TO DO IS OPEN THE TANK LID AND ON THE LEFT SIDE YOU'LL SEE THE BALLCOCK,AT THE TOP IT MIGHT HAVE A BLACK PIECE THAT YOU CAN SLIDE UP AND DOWN TO ADJUST THE WATER LEVEL,OR SOME HAVE A PIECE THAT LOOKS LIKE YOU CAN USE A PHILLIPS HEADS SCREWDRIVER,ALL YOU HAVE TO DO IS TURN IT A HALF OF TURN EACH TIME UNTIL THE WATER STOPS GOING INTO THE OVERFLOW TUBE ,WHICH IS USUALLY LOCATED IN THE CENTER OF THE TANK AND IT WILLBE 1INCH ROUND ,IT ALSO WILL HAVE YOUR FLAPPER OR BALL CONNECTER TO IT.
Apr 07, 2010 | Toto Toilet Onepiece Ultramax ...
RS 2545SH ICEMAKER
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 22, 2010 | Samsung Refrigerators
Ice machine is only making flakey size ice. Machine is clean and filters have been changed. Water is flowing and cold; it appears that the machine is in constant operation.
sounds like there is a problem with the water in the sump escaping. Sometimes, the plastic grate under the evap plates break and pieces get stuck in the dump valve. It is a triangular piece that the pump attaches to via a hose. It is spring loaded and the pieces prevent it from seating, thus, water leaks into the drain that you will not notice. When the water level in the sump gets low enough, it goes into a harvest and drops small slivers of ice. I'd check that out first.
Hope this helps.
Feb 09, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker in refrigerator is not making ice properly. ice comes out all together instead of in individual pieces.
your water is to high it can be adjusted but not recomanded also see if your unit is level that may also be a problem with the water.
contact me at www.911servicetoday.com
Dec 30, 2009 | Samsung RF265AA Bottom Freezer French Door...
My ice maker is not working...i replaced the maker but still no ice after 48 hrs...but i did notice ice stuck in the valve that goes into the maker..i pulled the chuck out..is that normal?
The ice frozen in the fill tube , is a sign of a bad ( seeping ) water inlet valve . Sounds like you needed to replace the water valve , instead of the icemaker , if the problem was " not making ice " . The water valve , is the piece the wall water line connects to on the back of the refrig .
Sep 21, 2009 | Refrigerators
GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Jul 23, 2009 | GE Refrigerators
U-Line BI-95 Logo
108 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
