Question about Hitachi 42PD3000 42 in. Plasma Television
I want to connect a Fire Fury hd connector to my 42PD3000 42" Plasma
Does this set have RGB 4:4:4 (8bits) digital input?
  • ian-wade Aug 25, 2008
    I am also up and running with HD Fury and I am also delighted with the picture quality using the PC connection. Thanks again for the help.
I have the same set and I've fitted a HD Fury to the RGB connection, I'm now watching full HD pictures via my Technomate 6900 combo Satellite receiver and Sony BDP300 blu-ray dvd player... it works and works very well indeed. Any questions on this mail me lhudlin@hotmail.com.
Loz
Posted on Aug 24, 2008
Panasoics plasma viera rv will not auto tune telling us to insert aerial already in Model TH-P50X20Z
The manual for this TV can be found here. If you are watching broadcast television, or cable TV service that does NOT require use of a set top "cable box" tuner, you would connect the coax cable from the UHF / VHF antenna or cable into the ANT cable connector on the rear of the TV as shown on page 8 & 9 in the manual.
You would then tell the TV setup to scan for available channels as shown on page 12 of the manual.
If you are using a seperate tuner - like those supplied by Cable TV, Dish, DirectTV, Satellite, etc. you should use (1) the HDMI 1, 2 or 3 inputs (HD) 720P and up; (2) the RGB inputs of AV2 for best picture quality 720P or better (HD), (3 & 4) the AV1 & AV3 (on the side next to HDMI) for 480i and possibly 480P (SD) and finally the ANT connector for 480i. If you have a computer that offers VGA jack to connect to an external monitor, use the PC connector on th erear of the TV to send it HD images.
Page 27 & 28 detail manual channel editing.
Mar 14, 2013 | Panasonic Viera TH-50PX80U Plasma TV
Stuck in RGB input.
i imagine your problem is over by now one way or another, but for anyone else experiencing this problem, thought i would share. your rgb input is tripped and needs to be reset, there are multiple things that "may" fix this, but the sure fire method is to connect a laptop to the rgb input, make sure you change your display settings on the laptop to "external monitor" and change the monitor selected in display settings on your computer. When the TV recieves a signal (which is what it is wating on and why it is frozen) it will then allow you to change input and will not turn off. Make sure your computer is running and all display settings are set before turning on tv so it does not time out and shut off before you can get it to pick up the signal
Jun 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Hd outputs or connectins
The only HD input on that monitor that is true HD is the 15 pin VGA input connector. It can be set in the TV menu to be used as an RGB input OR a color difference component input (Y, RY, BY). You will need a 15 pin connector that breaks out into 3 sperate cables; the ones I've seen break out into 3 BNC connectors and then you have to use dapators to convert them to standard RCA pulgs for connection to most consumer devices.
Oct 27, 2008 | Sony PFM-42X1 Plasma TV
Connecting dvd?
If everything is connected and dvd player is on, make sure you have the proper input selected on the TV. Input2 on this model TV. Try switching between the inputs.
An important thing you need to do is set the RGB input signal from PC to YUV or you won't have a good picture. This is done through the menu system
Jul 01, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
No video
try checking what your dvd is set on ie rgb pal or nstc, then check in your tv manual what inputs it accepts
Mar 25, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Rgb inputs dont work
the connection board or your digital board is bad change the connection board first it is cheaper, then if that does not solve the problem change the digital control board, this is the board where your control panel and connection board is connected to....
Oct 19, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
No video from rgb inputs
usually this is a bad connection on the system board, cable, etc.  If it's not under warranty, I would check the cable first, and try multiple video sources before opening the unit.  Worst case scenario is replacing the system board where the connections reside.
Hitachi 42PD3000 42 in. Plasma Television Logo
260 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
