Question about Vasco Digipass Go 3 (70403201249)
Blank screen after replacing battery - Vasco Digipass Go 3 (70403201249)
Satellite pro L300 screen is blank. Power light is on (green), battery light is yellow, HDD light is off.
Sounds like it's broke. Blank screen means it's broken, battery light is yellow I beleive it means time to replace the batteries.
Apr 16, 2011 | Toshiba Satellite Pro L300 Notebook
Screen went blank replaced AAA batteries starts up
You may have to force the calculator to boot up. Details are in the article . Read the part on Ti83Plus family.
The article contains links to additional articles.
Hope it helps.
Oct 25, 2009 | Texas Instruments TI-83 Plus Calculator
Timex Atlantis 100 screen went blank
same thing happened to mine. you might have cracked the inner screen and the only thing i can suggest is to replace it!
May 28, 2009 | Timex Atlantis 100 77511 Wrist Watch
Blank white screen wont go away
you need to now take out the battery leave for 1 min replace battery and turn on the phone
Jan 17, 2009 | Apple iPhone Smartphone
Screen goes blank before i can key in pin number
have the flexcable replaced and try also a new battery
Dec 27, 2008 | Motorola Mobility RAZR V3
Blank screen
Try removing the battery and putting it back in again. If it still doesn't come on it could be that the battery needs replacing.
Dec 22, 2008 | Uniden Cordless Phone
Axim x30 screen blanking
I've seen this twice>
take battery off pc and plug it in.
if it stops replace the battery.
if it does not your charging circuit in the pocket pc is gone south.
Mar 14, 2008 | Dell Axim X3 Pocket PC
My sidekick3 screen is blank
If your sidekick ID or Sidekick 3 screen is a blank white, then the lcd flex cable has come loose. It is a little difficult to repair but any one can do it. The worst that will happen if you try to repair yourself is that it will not work and you buy a replacement screen from ebay for 45 dollars.
Here are the detailed instructions. Just reinstall your lcd instead of putting a new one on.
Sidekick 3 LCD Screen Only Replacement
Here is a link to find lcd screen on ebay.
Sidekick 3 LCD Lens
Oct 27, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Screen goes blank
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Oct 14, 2007 | Timex Ironman Triathlon 51931 wristwatch
Vasco Digipass Go 3 (70403201249) Logo
310 people viewed this question
Top Vasco Computers & Internet Experts
David Payne
David Payne
Are you a Vasco Computer and Internet Expert? Answer questions, earn points and help others
