After working fine for several months, my computer won't recognize my SanDisk cruzer slice 4G. I have tried uninstall/install, scan for hardware changes in device manager and disable/enable, but no success. I have Windows XP Professional. The problem started as I was working on a Photoshop file stored on the device.
  • 3 Answers
SOURCE: Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Posted on Aug 23, 2007
  • 244 Answers
SOURCE: lost bluetooth radio in device manager
It is better to use external bluetooth to settle down your problem. I think it will only cost more or less $35.00 usb bluetooth.
Hope you like my solution please rate me SOLVE.
Thank you.
Philip
Posted on Nov 05, 2007
  • 2427 Answers
SOURCE: samsung cd-rw drive sh-r522 problem
IF THE DRIVE SHOWS IT ,, then its hardware
eighter the drive is defective or something is wrong with the MB/P
try the drive on a different computer if it works change your mother board format and reinstall
if it didnt work take it back for warrenty or get a new drive
Posted on Dec 30, 2007
SOURCE: Scansnap manager won't properly install on windows xp...
Problem solved. Ignore the "Windows XP approval" message & continue with the fix suggested in the troubleshooting section of the manual.
Posted on Feb 18, 2009
cheap to fix
  • 404 Answers
SOURCE: SanDisk Cruzer Titanium 4gb NOT WORKING !!!
bad news bro, the disk isnt initialized. your data is long gone only a data lab may get them back
Posted on Mar 11, 2009
I unplugged my USB before it was finished ejecting, and now when i plug it in neither my mac nor my PC recognize it, as in in it doesn't light up or even register that it's plugged in at all. It's as...
There are several reason why your flash drive is not working. You can try this and see if it will work:
STEP 1 - Connect the Cruzer to the PC
If you receive a "USB Device Not Recognized" error on the computer, the flash drive is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: The Cruzer might show up under several places under Device Manager such as:
1. Disk Drives
2. DVD/CD-ROM drives
3. Universal Serial Bus controls as USB Mass Storage.
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click on the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
STEP 4 - Verify if the flash drive is detected
1. Double-click My Computer.
2. Look for the Cruzer under devices with removable storage.
Feb 15, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When I plug in the flash drive it lights up but doesn't show up as a drive in "my computer". If I start the device manager (which shows the cruzer device as a funtional drive), disable it and...
1. Disk Drives
SOLUTION 4 -
There might be a conflict in drive letters, see Resolving drive letter conflict.
Oct 26, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I got amessage which say that USB Devise not recognize
There are different Ways to troubleshoot Your Problem
1. Verify if minimum operating system requirements are met.
2. Try other USB ports
3. Check status of the Cruzer under Device Manager
4. Connect the Cruzer to the PC
*. check under Device Manager
  • 1. Right-click My Computer, and select Manage
*. 2. On the top menu, click Action then select Scan for hardware changes.
*... STEP 4 - Verify if the flash drive is detected
Now the Other way
*. There might be a conflict in drive letters, see Resolving drive letter conflict.
Feb 19, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk doesn't recognized in computer
First connect your memory stic to other computer if it works there thne it has not any issue.
Then connect in your computer on which not recognized .
Then opem my computer if you can't see any removable storage then right click on my computer then go to its proeprty then hardware then device manager.
Then uninstall all usb drivers then restart computer then check .
If still face same issue then right click on my computer then click on manage thne go to disk management.then removable media/
check there if you find removable storage then right click on it then open or explore it.
if you still not recognized then when you power up the computer press F1 or F2 or "del' key to enter in BIOS.
Then go to advanced in bios then set LEGACY 2.0 enabled. then save settings and exit.
then check.
Aslo check your computer usb ports are working fine.
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Sandisk 2GB cruzer micro USB not detecting
go to my computer property then hardware then device manager then uninstall usb drivers then right click any driver and clik on scan for hardware then it install automatic usb drivers.
then restart computer then connect sandisk to computer then cehck if still face problem try all usb port of computer.
Aslo check your usb port of computer are working fine.
Aug 09, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Unable to read data on my cruzer 16 gb usb
then restart computer then connect pen drive to computer then check if still face problem try all usb port of computer.
also check your usb port of computer are working fine.
Thanks for using fixya.
Please rate solution if it helps you
Jul 23, 2009 | SanDisk Electronics - Others
SanDisk 2GB Cruzer micro - worked fine yesterday, plugged it in to the same computer this morning, the light flashed on then went off; computer does not see the divice; I have pulled and tried in other USB...
Right click on my computer icon then go to property then hardware then device manager then uninstall all usb drivers .
then right click on any driver then you see scan for hardware click on it then it automatic install usb drivers then restart computer then connect sandisk to computer.then check.
If it helps you please don't forget to rate this solution.
Jul 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My sandisk worked on my laptop but will not work on my computer. The computer doesn't even recognize the drive.
Jul 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer micro 4 gb
try to connect it firs to other computer, if other computer can detect it,format it..if not,that means your sandisk wont be usable anymore.
Oct 16, 2008 | SanDisk Cruzer Micro MP3 Player
SanDisk 4GB cruzer URGENT problem! Please, please help! :)
it may have overheated and became stuck. Stick it in a plastic bag and put it in the freezer for 1/2 hour then try it. Do not leave it out without power for long or moisture will condense on it.
Nov 28, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
