Question about Sony UP-CX1 Thermal Photo Printer
I need to get rid of the 1/4 white strip when I print a 4 x 6 on my Up-CX1
    President:
  • 2,047 Answers
Usually when prints dont come right they are mostly as a result of adjustments and alignments on the documents to be printed. Although atimes the problem could be from the paper which is put in for printing not being the same size with what the printer is expecting to print on.
What you should do is check the alignment of the document to be printed on the 4 x 6 if it is aligned with the 4 x 6 as in the sizing are equal. Then also check the settings when you are about to print to ensure that the settings are intact.
Also try to view a print preview before printing this will help more. And while the print preview displays you can always set the paper type and how you want it printed.
Hope this solution has been helpful??
Posted on Jan 01, 2011
Brother 7840 MFC blank stripe down every printed page
1. Turn off the machine's power switch. Unplug the telephone line cord first, disconnect all cables, and then unplug the power cord from the AC power outlet.
2. Lift the document cover.
In the ADF unit, clean the white bar (1) and the scanner glass strip (2) under it with a soft lint-free cloth moistened with water.
Note
In addition to cleaning the glass strip with a soft lint-free cloth moistened with water, run your finger tip over the glass strip to see if you can feel anything on it. If you feel dirt or debris, clean the glass strip again concentrating on that area. You may need to repeat the cleaning process three or four times. To test, make a copy after each cleaning.
3. Plug the machine's power cord back into the AC power outlet first, and reconnect all cables and telephone line cord. Turn on the machine's power switch.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 27, 2014 | Brother MFC-7840W Multifunction Laser...
Will not print a test page also unable to find or adjust spool settings and cannot change Priority settings. Some things will print but many items will not, even then it seems very slow.
Printing Problems
? The machine beeps while printing.
The machine may have a paper jam.
• Clear the paper jam (1 p. 13-3).
? Nothing prints.
The power cord may not be plugged in securely.
• Check that the power cord is plugged securely into the machine and into the wall outlet (1 p. 2-9). If the machine is plugged into a power strip, make sure the power strip is plugged in and turned on.
You may not have removed the plastic seal from the cartridge.
• Make sure you install the cartridge properly (1 p. 2-13).
The cartridge may need to be replaced.
• Replace the cartridge (1 p. 12-7).
? Printout does not match the print media size.
The print media may not be loaded correctly.
• Make sure the print media is loaded correctly in the multi-purpose tray (1 p. 5-4).
? Printout is skewed.
• Make sure the paper delivery slots are clear.
? Print media jams occur.
You may not be using the correct paper delivery slot.
• Select the correct paper delivery slot (1 p. 5-7).
? Printout is not clear.
You may not be using the correct print media type.
• Make sure you load print media that meets the requirements for the machine
(1 p. 5-2).
You may be printing on the wrong side of the paper.
• Some papers have a "right" side for printing. If the print quality is not as clear as you would like it to be, try turning the paper over and printing on the other side.
? Printout has vertical white streaks.
Toner may be low or unevenly distributed.
• Redistribute the toner inside the cartridge (1 p. 12-7). If the problem persists, replace the cartridge (1 p. 12-7).
Jan 03, 2011 | Canon FAXPHONE L80 Laser
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
I am having a problem printing with my HP printer
you wasted your time using cleaning program and heaps of ink...
follow this procedure:
1. remove all ink cartridges from the printer
2. check if ink is soluble in water, isopropyl alcohol or methylated spirit (this which do not create lumps or precipitations is correct solvent)
3. put one drop of solvent in th centre of aspiration hole on receptable
4. if solvent is absorbed through input, that meant problem is not with printer but with cartridges.
5. check printer cartridge by stamping them with tissue if they "produce" any ink on the outlet,
6. put one drop of solvent on cartridge outlet and insert them in correct bases
7. print test page, print should be rather weak as solvent will go through the nozzles
8. print test page from computer
9.create "strip page" of each colour used, separate by no colour (white) start with yellow strip, then white, light cyan, white, cyan, white, light magenta, white, magenta, white, black - this strip pattern will force all cartridge to operate on they max delivery.
if there is no result, service by technician will be in place...
all ink based printers need to print at least one page per week... ink will dry pretty fast, especially in dry or hot condition.
Jul 28, 2010 | HP C6250 InkJet Printer
I get an error code 5100. Printe does not start to
Hello Gurmi,
It may be that you need to clean your timing strip. (Download the manual from the usa canon website to learn more about the timing strip.)
Also, if cleaning the timing strip does not help, you may need to lubricate your purge cap. The purge cap is the white sliding mechanism that the printhead parks against when not in use.
1. Get yourself some white grease.
2. Remove the right printer panel to gain access to the purge mechanism.
3. Do not get any grease on the wipers or the black caps!
4. Moisten JUST the purge cap with the white grease.
Let me know if this solves the problem! Thanks - ambssdor
Dec 11, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Dell 3010cn white stripe
on the 3010cn open from cover, follow instruction for pulling up the lever and sliding the bar out of the side repeat the slide motion 15 to 20 time. this action cleans the printing plate and will elimiate the strip. the strip is caused be toner leaking on to the plate it the strip returns repeat the steps.
Nov 17, 2009 | Dell 3010cn Laser Printer
Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Jun 17, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I print my black and white invoices and the invoices have colored strips on them how do i get rid of that.
go to printer properties and click 'print in black only", so that printer wont even try to use colour cartridge at all.
Jun 04, 2008 | Office Equipment & Supplies
Sony UP-CX1 Thermal Photo Printer Logo
107 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
