Question about Fuji FinePix S5000 Digital Camera
My parents have a Finepix S5000 that is about five or six years old. You can no longer focus an image in any setting. The view of any image is extremely distorted. What do we do?
  • 3,083 Answers
Digital cameras focus by turning a focus lens inside, controlled by electromagnets from the main boards. Dust, dirt, lint or sand can work it's way inside and jam the focusing lens. You can try some compressed air ($4 WalMart), and spray it into the lens assembly, hoping to free it up. You can also try to gently bump the camera, with the palm of a hand, in the hope of freeing it up. The following blog talks about these and other things you can try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Although the blog deals with lens errors, some of the suggestions may help.
Otherwise, you can take it into a camera repair shop and get an estimate on repair. You can also contact Fuji for repair at:
http://www.fujifilm.com/support/
Sometimes, it's better to just get a new camera if the cost of repair is too high, especially with after Christmas sales now.
Good luck, and hope this helps.
Posted on Jan 01, 2011
Camera taking purple photos with lines
The image sensor has failed, the symptoms described are unmistakeable. You'll find that shots taken before the fault occurred display normally, confirming that the LCD anel is fine.
It's purely an age related issue and finally kills many digital cameras over six years old. The sensor has not failed prematurely as your camera was designed for a five year minimum lifespan. The only fix is to get the sensor professionally replaced (if available), but the cost far exceeds both the value of the camera and the cost of buying a brand new basic model which will still have a higher spec in most respects than your current model.
Your only fix is to recycle the camera and replace it.
Sep 24, 2010 | Fuji FinePix S5000 Digital Camera
FUJIFILM FINEPIX S5000.No image on viewfinder or LCD.
I think there is a small button on the back of the camera near the bottom that turns the viewfinder off and on I think. It should be in the manual.
It might have gotten bumped while in the bag.
May 24, 2010 | Fuji Cameras
Finepix S5000
It's a failed CCD imaging unit.
The only fix is to have it replaced, but your camera is now around six to seven years old and so it's beyond economic repair.
The spares are no longer available as the camera is past it's original design lifespan, if you did find a spare it would need professional fitting and the labour costs would far exceed the camera value.
For less than the repair costs, you could now buy the Fuji S1500 for about £120. It does pretty much all that your current model does and to a far higher standard.
Feb 03, 2010 | Fuji FinePix S5000 Digital Camera
My fujifilm finepix s5000 SN 4FL37025
This is the classic symptom of a failed CCD sensor. The only fix is to have the sensor replaced, but as the camera is around six to seven years old now any repairs will not be cost effective and you will likely have trouble sourcing the parts as Fuji stopped making their 3MP sensor many years ago. New, old stock sensors may also have degraded to the point where they are either faulty straight out of the box, or will develop the same fault within a few months of being powered up.
Sorry, but your camera has reached the end of it's useful lifespan: five years is pretty good going for any digital camera and six to seven is really exceptional. Digital cameras simply do not last anywhere near as long as many of the film cameras which they replaced.
Your only real choice is to buy a replacement, but if all you need is a similar technical specification to your current model then there are plenty of cameras for less than £100 (around $175 in OzDosh) which will do at least as good a job as your present camera. Just don't expect a sub £100 camera to last anywhere near even five years though.
One other advantage of an update is that you'll finally be ditching the expensive and highly inferior xD memory cards which were basically repackaged and slightly tweaked SmartMedia cards. If you buy a new Fuji then you'll find that they all take SDHC cards now (back compatible with SD cards) although they often still accept xD cards as well.
Sorry I can't be more positive, but I hope that I've still helped you. All that I ask in return is that you take a moment to rate my answer.
Jan 11, 2010 | Fuji FinePix S5000 Digital Camera
I had Fuji S5000 for about 3 years. It worked fine. Now all sudden, I can't see any image when trying to take a picture. Both image through view finder and on LCD are just blank. Someone told me that a...
Hi
I have got an S5000 that I can still view previously taken pictures from the card, but when trying to take pictures the screen and view finder shows a peculiar distorted purple and green picture and any picture taken is just a green blur.
I contacted Fuji and they say they can repair it for £90 (about $120)
Nov 02, 2009 | Fuji FinePix S5000 Digital Camera
FinePix S5000 The lens will not come out and it says no image.
you must be more specific; is that in view mode ?
What happens if you go to camera mode ?
Feb 22, 2009 | Fuji FinePix S5000 Digital Camera
Camera won't focus when using optical zoom
I had same problem. Found that doing a complete reset fixed it. Go into setup and at end there is a factory reset. If not working after that would suspect your ccd sensor is on way out. They should last 5-7 yrs. Be cheaper to get another cam with way prices have come down
Jan 08, 2009 | Fuji FinePix S5000 Digital Camera
Image failure
Caused by faulty CCD sensor ( see image bellow ) , but Fuji repairs  this fault free of charge because it is manufacturing fault, so I suggest you contact them.f825a63.jpg
Oct 22, 2007 | Fuji FinePix S5000 Digital Camera
Fuji S5000 will not diplay object on LCD Screen or Eye View
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager. check it out.
Sep 08, 2007 | Fuji FinePix S5000 Digital Camera
White Screen
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
Sep 25, 2006 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
46 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
