Question about Kitchen Ranges
Frigidaire PLES389ECD oven works, but none of the burners are working. Don't know what is causing this.
  • 3 more comments
  • Susan Ernst Jan 01, 2011
    The transformer input is 115vac, just not sure what the output voltage should be.
    I was getting a reading of 5 volts.
    What would I need to check to find out if there is a blown fuse link.
  • Susan Ernst Jan 02, 2011
    There is a thermal circuit breaker and it ohms out ok.
    I have checked the voltage and it is 220 to the unit. All switches are connected properly and I have replaced the main control board . It only corrected half my problem, the oven works now, but burners still do not work..
  • 1,531 Answers
You should have 220 volts to the unit at the main terminal bloack you will need to check that and make sure there is the correct amount of power.
then you will need to check all the wiring to the switches and make sure they are all connected properly.
Lastthing would be is to replace the main control board.
Posted on Jan 02, 2011
  • seth adams Jan 02, 2011
    Check and make sure there is continuity on all the safety thermastats located be hind the rear panel.the relay may also be mafunction and if this unit is equipped with a circuit board in the rear you might need to replace it.you will also need to che the saftey thermastat located on the front body panel below the electronic board
  • 2,926 Answers
The cook top has a separate transformer that supplies voltage to all of the burners. The transformer will need to be tested for input and output voltage to verify its operating condition. I have a wire diagram and can assist you for diagnostics if your comfortable with this. If not, a service call is required.
Posted on Jan 01, 2011
  • 1 more comment
  • GetMeOttaHere Jan 01, 2011
    Is there any voltage reading from the output??
    Is there a blown fuse link???
  • Cheryl Chandonnait
    Cheryl Chandonnait Mar 13, 2015
    what are the values for the power supply i get 230 for input and i get 5 volts for each black wire goimg out but the strange thing is one of my burners are working the left front with the only small yellow going on it , the rest wont work and another strange thing is the left rear will come on the display led and i keep getting a blinking green dot on the switch cant figure it out i need help
Burners wont work any more
Good Morning Fern mullen, I appreciate your post!
Based off what you have described your burners are no longer working on your Frigidaire range. This could be an issue with your control panel or the switch. I would recommend performing a reset on your range and you can do that by disconnecting power from the range for at least ten minutes. If that does not help correct your issue I would suggest having a technician out to your home for a proper diagnosis and repair. Best of luck! -Matt
Feb 28, 2015 | Frigidaire FGEF306TMF 30" Freestanding...
None of the element are not working
Does the top burners work at all? If they do, and the oven isn't working you could need a new element or a new control board. If nothing works, on top or on bottom, then the control board definitely needs to be replaced.
Aug 29, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
We have an 8 year old Frigidaire electric range. When going to use the oven a few nights ago, we discovered that neither the top or bottom oven burner was heating at all - tired both Bake and Broil. The...
You will have to check that the switch is is working ok , with a vault meter check for voltage at the burner , if none check at the switch and so forth back to the wall switch, if there is vaults at the burner it is faulty .
May 27, 2017 | Frigidaire FEF339E Electric Range
I have a frigidaire m/n PLES389ECD and the burners and oven aren't working and had the error code f20, the clock timer was replaced but now the clock is the only thing working the burners and oven still...
The ESEC system and the electronic oven control ain't communicating. Check the wiring connections between the oven control and the esec controls. The thang is designed to lockout the top burners while the self clean feature is in use. If you failed to reconnect that connection which feeds back to the ESEC I imagine nothing does work. LOL. here's a video which shows how it works and I have the manual loaded on Gdocs fo you.
30 Inch Freestanding Electric Ranges_Rev A (5995438461).pdf (4 megs) printable.
Dec 31, 2010 | Frigidaire Ovens
The lower burner in the oven of my Frigidaire Gallery Gas Range will not come on. The upper burner works fine.
The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | Frigidaire Gallery 30" Self-Cleaning...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Oct 15, 2007 | Frigidaire FED300AS Electric Kitchen Range
Kitchen Ranges Logo
144 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
