Question about Nespresso Citiz D110
When I load the Capsuale in to the machine it will not pearce. The pump starts, but water can not get through to make coffee.
  • 24 Answers
I have had four, yes four, of these machines all do the same thing. We think it is related to storage in cold weather, but all the machines have been left in properties with no heating. Best bet is to contact the experts: http://www.nespresso.com/uk/en/pages/coffee-machine-repair-service
Posted on Jan 15, 2011
Problems whith astoria argenta
Hi just a tip from experience, grind the coffee fine and keep the spout ( where the coffee comes out) very near the cup, while making the coffee.
Kolbrun
Mar 06, 2014 | Astoria Coffee Makers & Espresso Machines
No water coming through coffee filter. I have descaled twice. You can hear the pump but no water and then it goes quite with no water. I have tried to prime the pump but still does not work. The steamer is...
If you open the steam tap while the pump is running does water come out? if so then you might have a blockage in the coffee solenoid or the bottom of the boiler. Do you hear a 'click' sound when you hit the coffee switch? If not the coffee solenoid may not be operating. The most common cause of the problem you are having though, is scale flaking off the boiler walls causing a blockage where the coffee water comes out. Try hiting the coffee switch, opening the steamer and then if water starts pumping out, close the steamer and see if water starts flowing out the coffee group. Do this without the portafilter (coffee holder) in place.
If you do get water flowing trough the group, try backwashing the machine.
If these things dont help then you should take it to an authorised repairer or open up the boiler yourself if you are a handy person and have access spare parts. Good luck, these machines can make a great espresso when in the right hands and working order.
Dec 01, 2010 | Gaggia Classic Espresso Machine
My machine seems to be set on ventiate. it wil dispense hot water but that's it.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. I hope this helps , Lee Davidian
Dec 27, 2009 | Saeco Royal Digital Plus Coffee...
No water getting through to the coffee holder
If the machine is making very load noise while trying to make coffee ie. water to grinds or steamer this is more than likely a pump problem.
Dec 26, 2008 | Gaggia Baby Espresso Machine
No water comes out of the machine
usally load noise in a pump machine is that its getting air in to it.
trie and use a bellow pump and force the water in.
Jul 13, 2008 | Keurig Elite B40 Coffee Maker
Water problems seaco Italia
Have you professionally cleaned the grinder ( + burrs)? To do this, would have to open the machine, remove the burrs, & clean them.
Jul 07, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco cappuccino magic
inour water tank the bottom hole check if not full off calcium if not turn the machine on try to inject water in the hole maybe pump need some help to start if ok decalsefy the machine after good luck cheers
Jan 19, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Pump doesn't pump
Yes, it is called descaling. Use a descaling solution, or vinegar and water, and follow the procedure for flushing your machine. After that, re flush it with plain water- nothing worse than vinegary coffee!
Sep 17, 2007 | Philips Senseo HD-7810 Coffee Maker
Increasing water flow rate
Back-flush the machine regularly and check your water hookup and make sure you to not have a small diameter water line. Other than that it is controlled by the water pump I believe. If the solenoid (the silver thing attached to the pump) used to start the pump is old it could slow down the pump start cycle.
Jul 01, 2007 | Rancilio S24 Espresso Machine
Nespresso Citiz D110 Logo
1,107 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
