Question about Keurig Platinum B70 Coffee Maker
Will not brew, water runs back into reservior
  • Barrett Palumbo
    Barrett Palumbo Dec 31, 2010
    is this a new unit or old
    Scholar:
  • 149 Answers
Your pump is seized, call keurig for a replacement at 866-901-BREW.
If you're out of warranty, the repair instructions are as follows:
1) Unscrew the screws securing the k-cup arm top piece to the frame (look at the top needle, the screws are right by that)
2) Pull out the body piece, unscrew the 2 screws that secure the top cover to the unit. Pry up at the area near those screws to pop the top piece up more.
3) Remove the top cover from the brewer by removing the 4 securing clips (shine a flashlight into the gap, use a long screwdriver to disengage the clips). There is 1 on the left, 1 on the back side left, 1 on the back side right, and 1 on the right. Start on the left.
4) Remove the 2 screws above the LCD and the 1 screw on the opposite side. These secure the back cover to the unit.
5) Remove the bottom metal cover (you do not need to unscrew the rubber feet).
6) Remove the screws that secure the plastic frame to the bottom of the unit, the screws are located around the perimeter of the unit, there are 1 or 2 located in the center of the unit Remove the bottom pump for the water tank. Pry the frame out, be careful of the pump you just unscrewed.
7) Slide the back cover downward, and push it outward. Remove the back cover from the unit, or at least get it out of the way.
8) There is a small pump located on the lower right corner of the unit (underneath the transformer) Remove that, and disassemble it by removing the 3 screws on the bottom, and then the 2 screws located underneath the plastic layers.
9) Wash the pump with isopropyl alcohol, you may need to shake it or manually turn the pin to make it work. Test it using a 12V power supply.
10) Reassemble!
Posted on Jan 02, 2011
That description was helpful but if you dont want to get your hands dirty doing it and don't have alot of free time then throw it in the trash and go buy a new one. If you follow switch's directions to a T you will break you macine as there are screws and steps he didn't mention. Also you want to clean the PUMP MOTOR in alcohol not the PUMP. Cam
Posted on Feb 16, 2011
My keurig vue unit will no brew a full cup. bubbles come up in reservior when brewing stops
You did the correct procedure. You may have a line leak. If bubbles occur, air is getting into the line somehow. It could be the connection point or a small hole in the plastic line from the water reservoir to the heating reserve.
Jan 07, 2015 | Keurig Vue V700 Brewing System - 110774
DURING THE BREWING CYCLE IT ONLY BREWS 1/2 A CUP AND IT LOOKS LIKE WATER RUNS BACK INTO THE RESERVIOR.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 17, 2011 | Keurig Platinum B70 Coffee Maker
Brand new Mr coffee PSTX series coffee maker leaks water from the base while fluid level in reservoir drops even before the brew cycle is turned on. I have double checked the seating of the reservior but...
If you look where the reservior fits into the base, specifically where the water goes in, there is a rubber seal. It's held in by a circulary plastic piece and 3 screws. I took it apart there to see if something was amiss and decided after looking at it some that they had put the seal in upside down. So I put it back together with the lip of the seal facing up instead of down and I have not had a single drop of water leak from the reservior again. Now if I can get the thermos pot that came with it to stop leaking every time I pour a cup I will be a happy camper.
Aug 28, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Keurig B60 is real slow , displays brewing for 30 sec.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in the brewing holes and must be cleaned every once in a while. Refer to the owners manual on cleaning the coffee maker.
Jun 20, 2010 | Keurig B60 Coffee Maker
Unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
May 29, 2009 | Keurig Ultra In Home Single Cup Brewer...
I fill the resavior w/ water for a 12 cup Mr. Coffee and 2 1/2 cups evaporate while going through the motion and delivering less and less each time. I ran vinigar & water through 3 X's to no avail.
Are u sure that the water is still not in the reservior? After the partial brew, CAREFULLY check / empty the reservior for the missing water. If it's still there, then u probably have a clogged perculator hole at the bottom of the reservior.
I just figured out how to correct a slow / partial brew problem for a 4 cup Mr. Coffee that left the water in the reservior...I have been using paper towels and napkins to dry the reservior and cover after use, and apparently bits 'n pieces of paper clogged the tiny little hole at the bottom of the reservior that the hot water perculates through
Multiple vinegar/CLK flushes may eventually desolve this paper clot, but I used my vacuum cleaner with slat attachment to **** the paper clot out.
Aug 29, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee pot just would not brew this morning, though it worked fine yesterday morning. I emptied it and started over 3 times. The lights come on but that is all that comes on.
Check the water level. Check to make sure that the coffee filter under basket is clean and not plugged. YOu can remove your filter, then take out the basket and clean it....when did you purchase the machine?
Aug 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Brew Station Deluxe Model 47454
unit needs cleaned run a 50/50 mixture of white vinegar and water through it a few cycles and then a few cycles of clean water this should remove any deposits in it. this should fixya!!!
Dec 11, 2007 | Mr. Coffee APX33 Coffee Maker
Not Brewing
We have had this problem intermittently but we had a bigger problem that I solved yesterday. Our LCD display was not displaying properly - words were missing so we just had to guess when it was ready to brew. I called Keurig and they offered a new one for $100 since it was out of warranty. They did ask me if I had descaled the machine and, I'm embarassed to say, I had never done that. Well I descaled the machine and viola! - my LCD display completely came back just like new! Here's hoping the intermittent brewing problem is resolved as well! If you haven't descaled the machine recently, I would strongly suggest giving that a try for any problems you might be having. Of course, to descale, the machine has to at least be able to brew in order to get the vinegar through the machine...
Dec 04, 2007 | Keurig B60 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
1,318 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
