Question about General Refrigerators
My side by side the freezer part is frosting up
  • 1,772 Answers
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
The freezer side if frosted over.
Sounds like a fan caught. Empty and defrost fully, then restart and check all working
Apr 18, 2012 | Frigidaire Freezers
Frost on the evaporator
watch this video I made. this is subzero with low level of freon (almost out). same situation on all refrigerators and freezers. you can see ice at the begging of evaporator. if there would be a little more freon evaporator might of frost up at the top might frost half of evap other half would be not even cold.
Jan 28, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Fghs2665kf2 side by side freezer works fine fridge side warming up
The leading cause of the refrirgerator not working while the freezer is is good,is a defrost problem,do you see a bunch of frost built up on the back wall inside of the freezer?? If yes ya see frost build up of frost in the freezer it will be a problem with the automatic defrost system. This tip i wrote covers what to check when it isn't defrosting by itself.
http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 08, 2011 | Frigidaire Side By Side Refrigerator 26...
Freezer cold and fan running. Refrigerator side not cold, no cold air circulation. Wife says sound of refrigerator is lower pitch like something that used to be running is no longer running. Is there...
Hello Otis,
Thier is only one fan in the freezer that circulates the air throughout both ref/freezer. I dont know if ya have a side by side or if freezer on top..but if side by side one possible cause would be the damper in the upper left corner of the refrig. compartment is stuck closed so no air can enter ref.compartment(no damper if freezer on top or even if older model side by side) on either model also even if freezer on the bottom, another possible thing is frost has built up in the freezer and the coil in freezer is a huge block of frost and no air can poass through it because its totally frozen.
Let me know which might be the problem and i will help ya check that EI..is the damper stuck..is it all frosted up and ya can see frost on back plate of freezer wall ect ect..
Gene
Aug 23, 2011 | Refrigerators
Freezer is frosting
Even frost free freezers will frost up in high humidity, especially if there is a poor door seal. Defrost the freezer by turning it of and placing pans of hot tap water in the freezer. You can speed this along by helping to remove the ice as it melts. Check the door seal after you've defrosted the freezer, a bad seal is one of the big causes of frosting up the next biggest problem is usually holding the door open.
If it's a frost free unit, if the problem continues you'll need to have it checked out.
Jun 19, 2010 | GE GSS25JEM Side by Side Refrigerator
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Jun 10, 2010 | Kenmore 57029 Side by Side Refrigerator
My side by side freezer is now gathering frost
Try and do a manual defrost, unplug it. Bad seals around doors could be problem.
Nov 25, 2009 | KitchenAid KSCS25FKSS Side by Side...
Fridge side not working freezer frost on back at first now not freezing hardly at all
If you still have the frost build up on the back wall of the freezer, your problem is in the defrost circuit. You'll find a bad heater, terminator or control.
Also verify operation of the evaporator (freezer) fan.
Apr 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Feb 17, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
241 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
