Question about Dell 3110cn Laser Printer
I have an error message " 007-341" on my Dell laser printer 3110cn and i am wondering if this a diy fix?
SOURCE: Error 003-343 Dell 3110cn
Open the printer using the button on the side top right. You will see two gray things with arrows going left and right. move them both two where you can take out the piece it is hold in. Pull out the large piece and put it back in. Close the two gray things to lock it back into place. Close the printer and restart it. It should fix your issue. It must of became loose at one point when I was moving so I fiddled with it and turns out that was the issue. It works great now!!
Posted on Nov 09, 2008
  • 5 Answers
SOURCE: Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Posted on Jan 09, 2009
SOURCE: step by step - how to print envelopes with Dell 3110cn laser printer
floppy will not work
Posted on Feb 02, 2009
  • 165 Answers
SOURCE: Error message 016-370
You should try to reinstall the firmware update. It was interrupted and that could have led to this problem.
Posted on Apr 02, 2009
SOURCE: dell 3110cn - Load MPF 024-969 letter plain error msg
dell mfp laser 3115cn giving me 024-969 no paper detected
Posted on Nov 27, 2009
Display on Dell 3110cn says "belt unit close to life". what does that mean?
It means that some internal components needs to be replaced soon. I strongly suggest to hand this printer to repair service or local IT technician
Aug 19, 2011 | Dell 3110cn Laser Printer
I have a Dell Laser Printer 3110cn. I'm getting an error, 016-317, please restart printer on the screen. How do I fix this? Thanks, Sharon
I have the same problem. I tried everything I found on the forums (Google search for error 016-317) and finally ended up calling Dell support. Technician arrived at the conclusion that I needed a new system board - $350 for the board and $110 for the technician to come out and fix it.
I am looking for a cheaper mother system board and and hoping, in my search, I come up with another, cheaper, solution. Good luck to you.
Aug 04, 2011 | Dell 3110cn Laser Printer
We have an error message CRUM 009-367 and we are unable to figure out what is wrong with it on our Dell 3110cn. Thanks
009-367:The Yellow (Y) Toner Cartridge CRUM Data error is detected.
  1. Cycle power on the Printer.
    1. Turn the printer off.
    2. Wait 10 seconds.
    3. Turn the printer on.
    4. Determine if the issue still occurs.
  2. Verify that the toner installed is Dell toner
  1. Cycle power on the printer again.
  2. If the error persists, replace the desired toner cartridge.
    • If the desired toner cartridge has already been replaced, replace the Toner Dispenser CRUM.
    • If the Toner Dispenser CRUM has already been replaced, replace the Printer.
Mar 07, 2011 | Dell 3110cn Laser Printer
On my Dell 3110cn printer, I keep getting the following error message: "Error C Cart 093-919" I bought this refurbished yellow toner cartridge from a reputable dealer on EBAY and it is basicaly...
remanufactured toners, or off brand toners are sometimes not compatible. I would contact the dealer you bought the toner from and tell them the cartridge is defective and demand an exchange or refund.
Feb 23, 2011 | Dell 3110cn Laser Printer
My dell 3110cn printer is displaying the following Error code 009 363 reseat k cart how do i fix this?
This error message indicates that the printer has failed to read information from the chip on the black printer cartridge.
This is either.
1. Black cartridge not fully pushed into place (I've been called out to a couple like this)
2. Faulty chip on the black cartridge - effectively not responding to the printer 'talking' to it.
3. Fault on the main board of the printer.
Solution
1. Push the cartridge fully home.
2,3. If you have an old black cartridge, try that. The message should change to Replace Toner, if it does, its the chip on the cartridge, if it doesn't its the printer.
Oct 15, 2010 | Dell 3110cn Laser Printer
Message 009-371-reseat belt unit after replacing belt unit
Hi folks,
I have a Dell 3110cn and just got this message ... and I haven't touched anything.
In an attempt to FIX the problem, I have taken the Belt Unit out and put it back in.
No luck yet !
Jun 30, 2010 | Dell 3110cn Laser Printer
Apr 02, 2009 | Dell 3110cn Laser Printer
Dell 3110cn Laser Printer Logo
172 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
