Question about Maytag Neptune MDG5500AW Gas Dryer
The timer on my Maytag DG212 dryer sticks and does not advance so it just keeps running.
  • Maytag Master
  • 7,482 Answers
You will need to change out your timer, as it is non-repairable.
Hint:...Be sure to get the same brand/mfg of timer, or be somewhat of an electrician because if you do not get the same timer it will not be wired the same.
Also only remove and replace one wire at a time, it will keep you out of trouble and ease the installation of the timer.
Please rate me
Posted on Jan 01, 2011
Maytag dryer wont turn off
I thank you need a new Timer part# 3979617
Jan 21, 2013 | Maytag Dryers
My dryer keeps shutting off after a few 10 to 13 minutes...and clothes are not drying. An element was changed some time ago. it does heat up but keeps shutting down...is it the timer or element?
Turn the breaker to the dryer completely off and back on again. Also check that nothing is blocking the venting. Remove the vent hose and run the unit if you are not sure. Make sure the lint trap is cleaned first. It probably is neither element nor timer since it is heating and quits without the timer advancing completely.
Apr 05, 2011 | Maytag HYE3657A Electric Dryer
Maytag Dryer timer keeps running
I have looked at your dryer schematic. The only thing that moves the timer forward towards the end of cycle is the timer motor. You are going to need a new timer, looks like they have one for 54 bucks HERE
Feb 08, 2010 | Maytag PYE2300AY Electric Dryer
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Maytag electric dryer won't stop running.
temp selection switch is defective, replace.
nbcrca:)
Apr 11, 2009 | Kenmore 64902 Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Washer sticks in spin mode during most loads
hi there,
the timer is actually a mechanical switch. sounds like you have answered your own problem. it's time to replace the timer.
Oct 01, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag dryer PYE3300AYW Continuously runs
jefo, it sounds to me like your timer is not advancing. Does it move at all or stay in place? In what you are saying it will stop when you turn it to off, I would think it could be the timer that is the problem. Part # 53-1810.
May 19, 2006 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
107 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
