When i turn computer on it runs but the screen is blank
  • Jacqueline Perdue Dec 31, 2010
    What kind of laptop is it? Make, model and OS, please. Also, did it happen suddenly?
    Genius:
  • 1,288 Answers
Test the laptop on another external monitor, if you get an image there, the fault is probably with the laptop backlight
Posted on Jan 01, 2011
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
Will not boot up. blank screen
Can you see any light on your computer? Or hear your computer running? Have you tried turning of the power and turning it back on? Also check if the cables on the back of your monitor are still firmly connected. as well on the computer side.
Listen for the computer if it makes any kind of sounds when you turn it on.
Jan 08, 2015 | Computers & Internet
If i select source to pc display will become blank and power indicator blinking.
• You can check if the product is working properly using the Self-Diagnosis function.
• If a blank screen is displayed and the Power LED blinks even if the product and the PC are properly connected, perform
the self-diagnosis function according to the procedures below.
1. Turn the product and the PC off.
2. Separate the signal cable from the product .
3. Turn the product on.
4. If the product is working properly, the message appears.
In this case, if a blank screen is displayed again, make sure that there is no problem with the PC and the connection. The
product is working properly.
Is a blank screen displayed and does the power LED blink at
a 1 second interval?
1. This occurs when the power saving function is running.
If you click the mouse or press any key, the screen will be
turned on.
2. This occurs when two monitors are connected,
is and Magictune is running. In this
case, characters on the Magictune OSD may appear
corrupted. To run the Magictune, the must
be set to . Please restart your PC, set the
to and run the Magictune.
Jul 07, 2011 | Samsung BX2231 21 inch Monitor
I have a Compac computer that has Windows XP installed (SP2), when I start up the computer, the Windows XP will not run correctly. Once it seems to be opening Windows, my computer screen just looks blank...
When you are on the blank screen try to press CTRL+ALT+DEL on your keyboard at the same time. it should bring up the task manager window. now, click on FILE > New Task Run > Type in EXPLORER.EXE and press Ok. it should show you your Taskbar, desktop wallpaper, desktop icons
Oct 01, 2010 | Computers & Internet
When i'm online, my computer screen flickers then goes blank with a white screen. The computer is still running the screen just goes blank. how can i solve this problem? and sometimes when i turn on the...
Your computer is infected with spywares.You need to scan your computer for spywares from a good antispywares software like Malware byte, SuperAntispyware etc.
Jul 11, 2009 | Acer Aspire 4520-5141 Notebook
Computer turns on but screen wont
First,If you are running windows vista,This can be due to an update that has your video driver and windows video driver running at the same time.
Hardware would be the invertor board is bad.
Ttry to start with F8 and choose start in vga mode,If this allows you to start normally,go to the device manager and update the video drivers
Feb 22, 2009 | Toshiba Satellite P205-S6337 Notebook
Monitor is blank when we turn the computer on.
Maybe not. Find the FN key. It is usually BLUE in color
Then look on TOP row of Computer keyb (or all over) and find CRT/LCD.
Press the FN and that key and your screen should come back. You accidentally sw. it to CRT (outside, external monitor)
Jan 14, 2009 | IBM ThinkPad T23 2647 Notebook
White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Dec 30, 2008 | Acer Aspire 4315 Notebook
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
