Question about One For All URC-3021 Remote Control
Need the code for a HP CPTOH-0603 - One For All URC-3021 Remote Control
On my CPTOH-0603, i'm getting great picture but no sound. Just have antenna hookup directly. Would I need a receiver for the sound to come on? Or maybe not hooking it right.
the antenna is getting a good picture and as sound and picture are bound from transmission I am thinking that there is a problem in the sound board/ section of the tv
Mar 24, 2017 | Televison & Video
No picture or sound
It sounds to be the problem of the fuse .
Replace fuse in your tv will solve the problem .
SAM ANDERSON
Sep 23, 2008 | Televison & Video
Picture just went out on my tv but I still have sound
I have the same problem with my HP PL4260N 42" Plasma HDTV serial # CNH6141988, model # CPTOH-0602. I have perfect sound and can change channels still with sound but NO PICTURE. I am a consumer with a question that need the advise of an expert.
Apr 17, 2013 | HP PL4260N 42 in. Plasma HDTV
Problem with picture on HP Plasma TV
hello!
This is known problem with PDP displays. That means: one of X-buffers has bad connection to the PDP(plasma display). Or, in some cases, depend on PDP type, it could be panel itself at fault. You need to open your set carefully and get an access to X-buffers. Usually, at the very bottom of PDP, covered with aluminum heat sinks. By turning set on, while face down, start tapping slightly with isolated handle of medium size screwdriver. Observe, when line(s) vanished. That's where connection(ribbon cable) between PDP and X-buffer is compromised.
In some PDPs, those integrated into panel itself and nothing you can do, except to live with that or replace panel. Hope, you end up just reconnecting ribbons. Anyway, you must have very good technician background to do so.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
Hi i want an authorization code for adobe photoshop cs3 extended serial number: 1045-1090-6246-8353-3166-2968 activation number: 3130-3248-9753-5697-5578-0774-4063 activation type: normal: 194:13
my serial number :1045-1090-6246-8353-3166-2968
my activation number :4921-6762-4396-8235-0536-2470-4063
activation type Normal: 194:13:
my email :markum_flanca@yahoo.co.id
Sep 12, 2010 | Adobe Computers & Internet
I NEED A REMOTE CONTROL FOR HP PLASMA MODEL CPTOH 0710
Here is the place I get most all of my remotes from.
Follow this link:
www.Remotes.com
Put in your model number away you go.
If this is a newer model, you may want to call them at 1800REMOTES.
You will get faster service over the phone.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have managed to answer your questions and have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot give this post a “FIXYA” (Two Thumbs Up) rating then please comment to this post and I will try to help you further.
I try to provide the best FixYa experience.
May 22, 2009 | Hyundai HPT-4250 Television
Radio works intermittent - 0603 code / CHECK on the display
Some can go into "security mode" if power was lost. Popping sound doesnt sound good to me, VW often has seperate amp under driver dash. Id check all power sources but I bet the error code is mech failure.
May 11, 2009 | Car Audio & Video
One For All URC-3021 Remote Control Logo
131 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
