Question about NEC MultiSync 5FG (White) 17" CRT Monitor
In a move my NEC MultiSync 5FG monitor got disconnected from its BNC cable (5 BNC). Now I don't know which leads connects to which ports. Can anyone help?
  • 11,361 Answers
The cable should be labeled with R (RED video signal), G (GREEN video signal), B (BLUE video signal), V (Vertical Sync signal), and H (Horizontal Sync signal), so you just have to match the plug to the sockets.
I hope it is clear explanations.
Posted on Dec 31, 2010
Testimonial: "Yes very helpful. Thanks. My cable are colored coded, but no labels. Was not sure where the white lead connects to and where the black lead connects t"
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
Dec 02, 2013 | Nec Display NEC MultiSync PA271W-BK - LCD...
Hi, the side mounted USB ports on my NEC Multisync 90gx2 monitor do not work
The USB ports on the LCD is a USB hub. To use these ports you have to connect the input of the USB Hub of the LCD to one of the USB ports of the computer through a USB cable. You need a simple USB Printer Cable, which is easily available from any Computer Accessories store. Below is the picture of the cable. The normal USB plug (on the left) goes to the USB Post of the PC and the square one at the right should be connected to the LCD.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 12, 2011 | NEC-Mitsubishi MultiSync 90GX2 (Black) 19"...
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Jun 15, 2009 | Computers & Internet
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
Bought a new computer. Getting no signal from my multisync 1700V
check the device manager and see what it says for the monitor...I know you can press CNTRL+ F5 for monitor selection , try this if everything is good in device mngr
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
What cable do I buy
If it is a dvi monitor then you would need a dvi cable. VGA monitor would need a VGA cable. HDMI monitor would need a hdmi cable. If it is compatible with both dvi & vga and your video card has a dvi output then dvi is a better quality than vga. You can purchase the cable online at a store like cables2go. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | NEC MultiSync 1525X 15" LCD Monitor
NEC MultiSync 5FG (White) 17" CRT Monitor Logo
129 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
